AUsquirrel
Dual Stack VETH interfaces
Sun Sep 25, 2022 9:19 am
Hi Everyone,
Do you know if you can dual stack (IPV4 and IPV6) veth interfaces or if they support IPV6?
I tried to create one with an IPV6 address and it gave me "Error in Address - address expected" in winbox and an "invalid or unexpected argument base" from the command line so I suspect not. I also didn't find any documentation if I could.
Regards
AUsquirrel
sindy
Re: Dual Stack VETH interfaces  [SOLVED]
Mon Sep 26, 2022 10:46 am
Try adding the veth interface with an IPv4 address, and then attach an IPv6 address to it as to any other L2 interface. I don't know the details of the implementation so it may or may not actually deliver the IPv6 packets to its counterpart in the guest OS.
Znevna
Mon Sep 26, 2022 2:10 pm
My container gets an IPv6 addr via SLAAC (I have ND running on the bridge under which that veth sits). So it does the job, I guess?
sindy
Mon Sep 26, 2022 2:27 pm
This confirms that the IPv6 traffic does pass through the veth (provided that the container indeed gets an other than link-local IPv6 address).
AUsquirrel
Fri Sep 30, 2022 12:05 pm
Thanks guys.
I have added an address to the bridge and was able to static the docker address as well so I guess the answer is yes but not in Winbox directly.
Users browsing this forum: DanMos79, helleon, Kanzler and 114 guests
