Kvanas
Temperature on ROS 7+
Mon Sep 26, 2022 2:55 am
I would like to ask about the change since version ROS 7+.
I used a script to detect the temperature on version ROS 6 and today I found out that it no longer works on 7.
Previously, a value was returned directly, and now an array is returned.
.id=*e;name=temperature;type=C;value=43
I tried editing the script and using regex
([0-9][0-9]+[.][0-9])|([0-9][0-9])
but it doesn't work for me. I always get only true returned
:local temp [/system health get 1]
:local msg \
"$temp"
/iot mqtt publish broker="XXX" topic="stat/temp/" message=$msg
Does anyone know the solution.
Thanks a lot
Jotne
Re: Temperature on ROS 7+
Mon Sep 26, 2022 6:50 pm
This is the part of Mikrotik for Splunk scipt posted here: viewtopic.php?t=179960
As you see it tries one version to get the health information (new), if that fails, use the old format.
# Collect system health
:if ($SystemHealth) do={
	:do {
		# New version
		:foreach id in=[/system health find] do={
			:local health "$[/system health get $id]"
			:set ( "$health"->"script" ) "health"
			:log info message="$health"
	} on-error={
		# Old version
		:if (!([/system health get]~"(state=disabled|^\$)")) do={
			:local health "$[/system health get]"
Users browsing this forum: No registered users and 25 guests
