sligbot
can't seem to figure this out...
Fri Jan 21, 2005 12:14 am
I've been trying to setup 2 systems to pass data to one another but haven't had any success whatsoever...
If someone has any suggestions, they'd be greatly appreciated.
Here's where things stand...
Right now I'd be happy to hit my router (not Mikrotik router) at 192.168.0.1. System 1 has no problem to do so and I've connected System 1 to System 2 wirelessly and can ping and login using ssh successfuly without issue. My problem is that I'm trying to get System 2 to ping out to 192.168.0.1 and it just isn't working. I think I've got all the appropriate settings here. The idea is to bridge the two systems using either EoIP or (preferably) through routing. Suggestions are definitely appreciated.
System 1
NIC IP address: 192.168.0.21/24
Atheros IP address: 10.0.0.1/24
Routes:
C - connect, S - static, r - rip, b - bgp, o - ospf, d - dynamic
# DST-ADDRESS G GATEWAY DISTANCE INTERFACE
0 A C 10.0.0.0/24 wlan1
1 A C 192.168.0.0/24 ether1
2 A S 0.0.0.0/0 r 192.168.0.1 ether1
NAT:
0 chain=src-nat out-interface=wlan1 src-address=192.168.0.0/24
action=masquerade
System 2
NIC IP address: 192.168.0.20/24
Atheros IP address: 10.0.0.5/24
Routes:
1 A S 192.168.0.0/24 r 10.0.0.1 wlan1
2 A S 0.0.0.0/0 r 10.0.0.1 wlan1
Routes:
0 chain=src-nat out-interface=wlan1 src-address=10.0.0.0/24
action=masquerade
Thanks in advance,
Rich
YazzY
Fri Jan 21, 2005 12:45 am
I think one of following ways should meet your needs:
1. You can remove IPs on the wireless interfaces and bridge them with your NICs (or bridge WDS with your NICs). Then you can assign IP's to the bridge instead.
2. Bridge WDS or WLAN interface with your NIC and set up firewalling rules on your bridge so you dont mix both the networks together which can create some weird loops.
3. Try to add route to DST-ADDRESS 192.168.0.0/24 with preferred-source 10.0.0.5 and gateway 10.0.0.1 on System 2
edzix
Fri Jan 21, 2005 9:13 am
there is actual-interface parameter under '/ip address' menu. So, there is no need actually to rest that IP wlan has to the newly created bridge interface. It could stay there as it is.
Edgars
Users browsing this forum: No registered users and 98 guests
