liveup
l2tp,on up scripts get src.address?
Tue Sep 27, 2022 4:23 am
I want to add the public IP accessed by the client to the IP white list when I successfully link l2tp
In this case, ROS only opens port mapping to whitelist IP addresses
liveup
Re: l2tp,on up scripts get src.address?
Tue Sep 27, 2022 3:12 pm
tdw
Tue Sep 27, 2022 3:27 pm
Scripts are not needed, create a PPP profile including an address-list= property. Client addresses will be added to the list when the session is established, and also removed when the session terminates.
nichky
Wed Sep 28, 2022 4:42 am
just to be more clear
The script that @liveup found will cake the ip-add which is hitting the router (public). PPP profile address-list will cake the remote ip-address.
Users browsing this forum: No registered users and 22 guests
