rayman1366
cannot upgrade lhg5
Tue Sep 27, 2022 7:25 pm
i have lhg5 6.49.6
but when i download and install 7.5 version nothing happened?!
why?
mkx
Re: cannot upgrade lhg5
Tue Sep 27, 2022 9:10 pm
The reason is that your device has "unbundled" install of v6. Netinstall seems to be the only way out of this situation.
rayman1366
Wed Sep 28, 2022 6:39 am
thank you, but big problelm now is that netinstall cannot detect lhg5 now. tierd many times with netinstall...i dont know why not working
mkx
Wed Sep 28, 2022 9:00 am
Netinstall is a very fragile process but it succeeds eventually (unless the netinstall-able ethernet port of device is broken). So do keep trying and apply all the tricks mentioned in the netinstall manual. One of tricks that seems to help most frequently, is to place a dumb switch between management PC and MT device (which seems to be necessary due to how Windows transitions ethernet interface between connection states, including a dumb switch makes windows believe that ethernet connection is alive all the time).
Users browsing this forum: No registered users and 59 guests
