defty
RB4011 "freeze" after enabling switch2 cpu ports
Tue Sep 27, 2022 11:42 pm
Hi
The title says it's all.
If I try to enable any of the ports what powered by the switch2 cpu (6-10) the RB4011 freeze, getting very slow, showing false informations about the ports ( it shows its RS ) while there is no cable attached in the port.. and measuring incredible TX/RX speeds (like 34.4 Gbps).
And the device is hot as hell. Even with proper ventilation.
For now, I disabled those ports, and there is no problem right now, we can use the Router, but it is very frustrating..
Does somebody got any idea why does this happens?
mkx
Re: RB4011 "freeze" after enabling switch2 cpu ports
Wed Sep 28, 2022 9:02 am
If this happens with multiple different ROS versions (6.48.6 as v6 long-term, 6.49.6 as v6 stable, any recent v7 such as 7.5), then it's most likely a hardware failure.
defty
Wed Sep 28, 2022 12:24 pm
I did ROS update from 6.47 factory default to 7.5 .. I'll try to downgrade to 6.49.6.
aTOMico
Wed Sep 28, 2022 6:27 pm
i use RB4011 with ROS V6.49.6 and the ports you said with no problems.
Best Regards
k6ccc
Wed Sep 28, 2022 6:45 pm
I'm like aTOMico, I use all ten of the Gig ports (nothing in the SFP) on my RB4011 with ROS v6.49.6 without issue. Temperature shows 32 C in an air conditioned data cabinet.
Sounds like a hardware problem to me.
Znevna
Wed Sep 28, 2022 7:52 pm
Hi
Is this a new unit? What's the history behind it?
Users browsing this forum: BoraHorza, Majestic-12 [Bot] and 184 guests
