meitscha
non VLAN and VLAN on ether 3 - VLAN no Internet
Wed Sep 28, 2022 9:14 am
Hello everyone.
I got an MT rb750gr3 on Monday.
i have after the MT an Asus xd4 mini mesh wlan and want to seperate the normal Network (192.168.3.0) and the guest network (192.168.101.0).
i have the mesh on ether3 with an dhcp for lan network and made a VLAN501 also on ether3 with dhcp.
normal LAN works perfect.
VLAN501 dhcp works, but clients have no Internet Access --> but i see the clients on the firewall connections (syn)
i have cleared all firewall rules, only the NAT Rule is activated.
#Attachment -> config file
does anyone have ideas how to get the vlan to get internet access?
thanks
anav
Re: non VLAN and VLAN on ether 3 - VLAN no Internet
Thu Sep 29, 2022 4:48 pm
Id say the issue is the connection to your Asus. The MT port is carrying untagged traffic on ether3, and tagged vlan traffic on ether 3.
How does the ASUS handle this,,,,,,,,,,,,,,,
Buckeye
Forum Veteran
Forum Veteran
Fri Sep 30, 2022 8:18 am
I concur, and this seems indicate that the Asus xd4 does not support vlans. The only place in the document where vlans are discussed is this (after point 5 in preparation). "By using AiMesh/ZenWiFi system, please make sure the node ports are NOT connected to trunk ports." You can read that as "if you are connecting this to a managed switch, only connect it to an access port."
Znevna
Fri Sep 30, 2022 9:10 am
How did you configure the vlan on the Asus device(s) ?
Users browsing this forum: Bing [Bot], loloski, mostfa228 and 32 guests
