I have a RB4011iGS+ which ethernet's default-name have changed :
ether1->5 default-name=ether6->10
ether6->10 default-name=ether1->5
This append after a reboot of the router. The fact is that I have a script on the router that get the mac adress of the ether1 doing :
Code: Select all
:local eth1mac [/interface ethernet get [find default-name=ether1] mac-address]
This seems to be the only impact (mac adresses did not change on the physicals ports, nor assigned names, IPs etc.)/
ROS version : 6.47.10, current Firmware : 6.47.10
Does anyone have an idea of the cause ?
Regards,
