markeczzz
InterVLAN Routing
Wed Sep 28, 2022 2:52 pm
Hi!
I have RB4011iGS+ configured with vlans.
On Router ports 1,2 and 3 are connected 3 switches with trunking enabled for all vlans.
On ports 4,5 there is a bond and there are 2 switches connected (active/passive switch setup)
Everything is working ok, full speed (1Gbps), except when transfering data from one vlan to other.
In that case I get around 200Mbps.
I don't have any rules that are limiting traffic and there is fasttrack rule on first place.
If I check resources used, I can see 1CPU core is at 100% and "networking" process is utilizing most of that.
Any solution how to speedup intervlan routing?
add name=Bridge
/interface vlan
add interface=Bridge name="VLAN 12 - VLAN12" vlan-id=12
add interface=Bridge name="VLAN 13 - VLAN13" vlan-id=13
add interface=Bridge name="VLAN 14 - MGMT" vlan-id=14
/interface bonding
add mode=active-backup name=BondSwitches primary=ether4 slaves=ether4,ether5
add bridge=Bridge frame-types=admit-only-vlan-tagged ingress-filtering=yes interface=ether1 multicast-router=disabled
add bridge=Bridge frame-types=admit-only-vlan-tagged ingress-filtering=yes interface=ether2 multicast-router=disabled
add bridge=Bridge frame-types=admit-only-vlan-tagged ingress-filtering=yes interface=ether3 multicast-router=disabled
add bridge=Bridge frame-types=admit-only-vlan-tagged ingress-filtering=yes interface=BondSwitches multicast-router=disabled
/interface bridge vlan
add bridge=Bridge tagged=Bridge,ether1,ether2,ether3,ether4,ether5,BondSwitches vlan-ids=12
add bridge=Bridge tagged=Bridge,ether1,ether2,ether3,ether4,ether5,BondSwitches vlan-ids=13
add bridge=Bridge tagged=Bridge,ether1,ether2,ether3,ether4,ether5,BondSwitches vlan-ids=14
mkx
Re: InterVLAN Routing
Wed Sep 28, 2022 8:39 pm
Inter VLAN routing is routing nonetheless. And it's subject to all of its peculiarities, one is that packets belonging to same connection will be handled by same CPU and if one is testing throughput with single connection (e.g. single SMB/SFTP/... file transfer), then choking single CPU core is to be expected.
BTW, is the bond (active-backup) HW offloaded? If it isn't, then it'll consume excessive CPU resources also for intra-VLAN transfers (but will still allow wire speed).
markeczzz
Thu Sep 29, 2022 9:31 am
So in that case, only solution to speed up single connection throughput would be to get router with better hardware? If yes, which one would you recommend?
Since rest of my network is 10Gbps, i was already thinking of buying router with SFP+ ports that supports 10Gbps, but I guess for that case I would need huge amount of cores that would support that kinda throughput im multiple connections.
Bond is HW offloaded as far as I can see:
/interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
 #     INTERFACE                                    BRIDGE                                    HW  PVID PRIORITY  PATH-COST INTERNAL-PATH-COST    HORIZON
 0     ether1                                       Bridge                                    yes    1     0x80         10                 10       none
 1     ether2                                       Bridge                                    yes    1     0x80         10                 10       none
 2     ether3                                       Bridge                                    yes    1     0x80         10                 10       none
 3     BondSwitches                                 Bridge                                    yes    1     0x80         10                 10       none
holvoetn
Thu Sep 29, 2022 9:41 am
That but what also helps is to be careful about which device/connection you put on which VLAN.
Devices transferring frequently large amounts of data with each other, should be placed on the same VLAN.
Then this problem does not occur for that transfer.
I have a NAS which I mainly use to make nightly backups from my PC.
Those 2 are in the same VLAN. Parts of my network devices can access that NAS too but not at the same speeds.
Similar when I do Wifi testing. I have one SSID which is in the same VLAN as a local iPerf server I have running. Then I know the VLAN-handling is not the limiting factor when testing some settings.
ksteink
Thu Sep 29, 2022 6:08 pm
You need to consider:
- Run ROSv 7.xx. If you are using version 6.xx you will not get the benefit of L3 HW off-load
- I didn't see that you have enabled vlan filtering on in your configuration.
mkx
Thu Sep 29, 2022 6:52 pm
All ports have HW offload enabled (by configuration) but none have it active. If HW offload was active, you'd see a 'H' in the second column (first column is index and third column is interface name). We'd have to see full config to make educated guess about why HW offload seems not to be active.
markeczzz
Fri Sep 30, 2022 12:26 pm
Sorry for late reply.
Yes, I do not see "H"
Also I am using version 6.49.
This is new configuration that I am testing with
add name=Bridge
set [ find default-name=ether10 ] comment=WAN
/interface vlan
/interface bonding
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
add address=192.168.100.2/24 interface=ether10 network=192.168.100.0
add address=192.168.12.1/23 interface="VLAN 12 - VLAN12" network=192.168.12.0
add address=192.168.13.1/23 interface="VLAN 13 - VLAN13" network=192.168.13.0
add address=192.168.14.1/24 interface="VLAN 14 - MGMT" network=192.168.14.0
add action=fasttrack-connection chain=forward comment="Fasttrack" connection-state=established,related log-prefix=fasttrack
add action=accept chain=input dst-port=8291 protocol=tcp
add action=accept chain=forward  connection-nat-state=dstnat protocol=tcp
add action=accept chain=input connection-state=established,related
add action=accept chain=forward  connection-state=established,related,untracked
add action=drop chain=input connection-state=invalid
add action=masquerade chain=srcnat out-interface=ether10
add distance=1 gateway=192.168.100.1
mkx
Fri Sep 30, 2022 9:01 pm
There isn't anything obvious that would disable HW offload in the fraction of full config you chose to post. As I wrote: we would have to see full (that's complete) config. I'll refrain from posting anything else regarding this thread until you post it.
Znevna
Fri Sep 30, 2022 10:45 pm
It's pretty clear (even stated in the first post) that there's a bond configured, which disables hardware offload on RTL8367 chips.
Check the documentation provided:
https://help.mikrotik.com/docs/display/ ... Offloading
Cheers.
thomsen
Thu Mar 30, 2023 1:09 pm
Hi all!
Did I understand correctly that in RouterOS v6 this problem (slow inter-VLANs speed) has not been fixed and i should to upgrade to RouterOS v7 ?
Users browsing this forum: dioeyandika, lurker888, NetHorror, raiser and 93 guests
