ZCSadmin
VLAN filtering on RB5009
Wed Sep 28, 2022 9:00 pm
I am trying to learn the correct config settings for setting up a new RB5009 to replace a hAP router in our small network, segmented with vlans.
I attached an image showing the VLAN/Trunks goal, with ether1 being the WAN port, and a mix of trunk and untagged ports.
I don't have a config to share just yet as I am still in the learning phase, the settings seem quite different from the old router, so want to make sure I am following along accurately, after reading many posts here about VLAN's on this model router.
I think - THINK I need the following for the bridge with vlan interfaces.
add name=bridge protocol-mode=none
add bridge=bridge comment=Trunk interface=sfp-sfpplus1 ingress-filtering=yes frame-types=admit-only-vlan-tagged
add bridge=bridge comment=Access interface=ether2 ingress-filtering=yes frame-types=admit-priority-and-untagged pvid=10
add bridge=bridge comment=Access interface=ether3 ingress-filtering=yes frame-types=admit-priority-and-untagged pvid=10
add bridge=bridge comment=Access interface=ether4 ingress-filtering=yes frame-types=admit-priority-and-untagged pvid=20
add bridge=bridge comment=Trunk interface=ether5 ingress-filtering=yes frame-types=admit-only-vlan-tagged
add bridge=bridge comment=Trunk interface=ether6 ingress-filtering=yes frame-types=admit-only-vlan-tagged
add bridge=bridge comment=Trunk interface=ether7 ingress-filtering=yes frame-types=admit-only-vlan-tagged
add bridge=bridge comment=Access interface=ether8 ingress-filtering=yes frame-types=admit-priority-and-untagged pvid=99
/interface bridge vlan
# Trunk ports
add bridge=bridge tagged=bridge,sfp-sfpplus1,ether5,ether6,ether7 vlan-ids=10,20,30,40,99
# access ports
add bridge=bridge untagged=ether2 vlan-ids=10
add bridge=bridge untagged=ether3 vlan-ids=10
add bridge=bridge untagged=ether4 vlan-ids=20
add bridge=bridge untagged=ether8 vlan-ids=99
Does this look accurate for what I am trying to do? I read through the VLAN guide, and is how I setup the old router vlans, and everything works fine. This new router seems a bit different. On my first try I locked myself out after enabling vlan filtering, so I figured I need to learn the basics of what I am trying to do, then will tackle it again once I have a better understanding.
Thank you
anav
Re: VLAN filtering on RB5009
Thu Sep 29, 2022 4:43 pm
Did you read through this...... viewtopic.php?t=143620
ZCSadmin
Thu Sep 29, 2022 5:34 pm
Yes, and a few guides over on network berg on youtube.
Here is how far I have gotten so far, thought I had enabled vlan filtering last night, and some other ip pools, but I see this morning it's not enabled. So taking another stab at it, and see if I can get packets flowing the right way, then the firewall rules. ether8 is my management or BASE so I don't lock myself out again.
# jan/01/1970 19:55:03 by RouterOS 7.4
# software id = GJYP-PF1L
# model = RB5009UG+S+
# serial number = xxx1212xxx
/interface vlan
add comment=Users interface=bridge name=VLAN10 vlan-id=10
add comment=CCTV interface=bridge name=VLAN20 vlan-id=20
add comment=Guest interface=bridge name=VLAN30 vlan-id=30
add comment=SRV interface=bridge name=VLAN40 vlan-id=40
add comment=MGMT interface=bridge name=VLAN99 vlan-id=99
add comment=JF name=WAN
add comment=JF name=LAN
add comment=JF name=VLAN
add comment=JF name=MGMT
add name=dhcp_pool1 ranges=192.168.120.2-192.168.120.254
add address-pool=dhcp_pool1 interface=ether8 name=dhcp1
add bridge=bridge comment=Trunk frame-types=admit-only-vlan-tagged interface=sfp-sfpplus1
add bridge=bridge comment=Trunk frame-types=admit-only-vlan-tagged interface=ether5
add bridge=bridge comment=Trunk frame-types=admit-only-vlan-tagged interface=ether6
add bridge=bridge comment=Trunk frame-types=admit-only-vlan-tagged interface=ether7
add bridge=bridge comment=Access frame-types=admit-only-untagged-and-priority-tagged interface=ether2 pvid=10
add bridge=bridge comment=Access frame-types=admit-only-untagged-and-priority-tagged interface=ether3 pvid=10
add bridge=bridge comment=Access frame-types=admit-only-untagged-and-priority-tagged interface=ether4 pvid=20
add bridge=bridge tagged=bridge,sfp-sfpplus1,ether5,ether6,ether7 untagged=ether2,ether3,ether4 vlan-ids=\
    10,20,30,40,99
/interface detect-internet
set detect-interface-list=WAN
add interface=ether1 list=WAN
add interface=bridge list=LAN
add interface=VLAN99 list=MGMT
add interface=VLAN10 list=VLAN
add interface=VLAN20 list=VLAN
add interface=VLAN30 list=VLAN
add interface=VLAN40 list=VLAN
anav
Re: VLAN filtering on RB5009  [SOLVED]
Thu Sep 29, 2022 5:58 pm
That is not your complete config, no firewall rules and vlan filtering is not enabled ??
(1)
Dont think you are following the link I provided at all and worse a complete lack of understand of the vlan filtering method.
If you did read and profess to know ...........how do yo explain this setting...
10,20,30,40,99
Should look more like.
add bridge=bridge tagged=bridge,sfp-sfpplus1,ether5,ether6,ether7 vlan-ids=30,40,99
add bridge=bridge tagged=bridge,sfp-sfpplus1,ether5,ether6,ether7 untagged=ether2,ether3 vlan-ids=10
add bridge=bridge tagged=bridge,sfp-sfpplus1,ether5,ether6,ether7 untagged=ether4 vlan-ids=20
ZCSadmin
Thu Sep 29, 2022 6:17 pm
(1)
10,20,30,40,99
Don't know much, still trying to get my head around the concepts (if not obvious lol) - Must admit I was in winbox messing with the vlans in 'safe mode' and somehow lost a portion of the config settings somehow. Still working on the firewall rules. Thanks for the syntax tip.
anav
Thu Sep 29, 2022 6:38 pm
For firewall rules........
viewtopic.php?t=180838
ZCSadmin
Thu Sep 29, 2022 11:31 pm
Thanks for your help anav
Buckeye
Forum Veteran
Forum Veteran
Fri Sep 30, 2022 12:26 am
@anav has a good Thread with many links to useful information here New User Pathway To Config Success. Section C has stuff you should review. Don't overlook the links to the official documentation, it is worth reading, and has some examples, and the reason for @anav's response in post #4. See this note in this section Trunk/Access port setup where it has this:
And note @anav's avatar. He often uses hot language and is stubborn. In his own words, it's his way or the highway if want help from him.
ZCSadmin
Fri Sep 30, 2022 3:37 pm
Thank you for the links Buckeye, I can use all the help I can get. Much appreciated, I don't know how anav puts up with idiot newbies like me, but I am learning.
Users browsing this forum: FIBRANETPLUSISP and 48 guests
