jharry
Mikrotik IP Cloud Service...selectable IPv4/IPv6
Thu Sep 29, 2022 1:50 am
Hi Guys,
I'm running rOS 7.5 and wondering if there is a way to only associate the xxxxxxxxxxx.sn.mynetname.net used by the cloud service to the external IPv4 ONLY. Not the IPv4 and IPv6 address. The reason I ask is because typically with IPv6 you don't firewall your servers the same way as with IPv4 and while an IPv6 is more complex the corresponding DDNS name might be easily guessed/known exposing the server to a range of attacks via the DDNS name.
As it currently stands the mikrotik serial numbers are long enough to deter someone from trying to spoof or guess them but if that list of serial numbers ever gets out it could be problems for people using the Mikrotik cloud service.
Is this something that the dev team can implement via a tick box option.
Regards,
Znevna
Re: Mikrotik IP Cloud Service...selectable IPv4/IPv6
Thu Sep 29, 2022 8:00 am
[...]typically with IPv6 you don't firewall your servers the same way as with IPv4[...]
Maybe you don't, but almost everyone else does (I'm sure there are other folks out there like you), even the default MikroTik IPv6 firewall rules are enough to protect the router and what's behind it.
Block IPv6 communication to the MikroTik cloud service and your ddns won't get an IPv6 addr.
Sob
Thu Sep 29, 2022 1:30 pm
But regardless of reasoning, ability to choose between IPv4/IPv6/both could be useful.
Znevna
Thu Sep 29, 2022 1:40 pm
Sure, in a feature request.
jharry
Fri Sep 30, 2022 8:29 am
Thanks for your replies, how do I request this as a feature?
Znevna
Fri Sep 30, 2022 8:39 am
You create an account here: https://help.mikrotik.com/servicedesk/s ... on=portals
After that, there's a "Suggest a new feature" section.
Or write in this endless topic: viewtopic.php?t=45934
Users browsing this forum: Bing [Bot], GoogleOther [Bot] and 217 guests
