Artnet44
Paramiko: Interacting with "source:" within scripts
Thu Sep 29, 2022 11:03 am
hello everyone,
I have hit a dead end with loading a ppp dropping script on my routerboards.
Due to the massive amount of devices that require the script, I need to somehow automate it.
I have tried using Paramiko with python, to load the following script onto the unit:
/system script
add dont-require-permissions=yes name=ppp-dropper owner=admin policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive source=":log in\
fo message=\"PPP-DROPPER RUNNING\"\r\
\n/ppp active\r\
\n:foreach i in=[/ppp active find] do={\r\
\n remove \$i\r\
\n}"
As far as I can tell it seems paramiko is having trouble executing the line breaks, I have tried removing them and using multiple different ways to send the command with no luck. (eg. reading it from a file and sending via routeros_api library)
The stdout I am receiving from the routerboard is as follows:
b'syntax error (line 1 column 72)\nexpected closing brace (line 2 column 5)\nsyntax error (line 1 column 8)\nsyntax error (line 1 column 61)\n'
Here is the current python code, although this code has been changed multiple times to try different angles.
import paramiko
ip = r"[redacted]"
iplist=[line.strip() for line in open('ips.txt')]
print(iplist)
def EsxCli(ipaddress):
client = paramiko.SSHClient()
client.set_missing_host_key_policy(paramiko.AutoAddPolicy)
client.connect(hostname = ipaddress , port='22', username='redacted',password='redacted',look_for_keys=False)
stdin,stdout,stderr = client.exec_command('''/system script
fo message=\"RUNNING PPP-DROPPER SCRIPT\"\r\
\n/ppp active\r\
\n remove \$i\r\
\n}"
/system scheduler
add interval=1d name=PPP-Dropper on-event=ppp-dropper policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=\
feb/25/2020 start-time=00:01:00''')
output_read = stdout.read()
print(output_read)
def StopVsfwd():
for j in iplist:
print(j)
EsxCli(j)
StopVsfwd()
Is there another way to interact with the "source" section or any subsection for that matter with paramiko or some other library?
This script executes perfectly when copy + pasted into the terminal on the routerboard, but this is not a viable route to go because I need to change thousands of routers.
Any advice would be greatly appreciated.
Artnet44
Re: Paramiko: Interacting with "source:" within scripts  [SOLVED]
Thu Sep 29, 2022 12:20 pm
For those having a similar issue, finally resolved it with this:
/system script add dont-require-permissions=yes name=ppp-dropper owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive source=":log info message=running script /ppp active :foreach i in=[/ppp active find] do={remove \$i"}
Just note the break infront of $
Seems routerOS works with no breaks or special characters in the code.
Users browsing this forum: No registered users and 21 guests
