rendezz
REST API causes high load
Thu Sep 29, 2022 3:37 pm
There is quite a bit problem with the REST api
On a single core mikrotik, the CPU will spike to 100% on a REST call
From the API docs
curl -k -u admin: https://10.155.101.214/rest/system/resource
on a single core CPU will return a cpu-load of greater than 90%.
If you add a query parameter onto that
curl -k -u admin: https://10.155.101.214/rest/system/resource?.proplist=cpu-load
The CPU will rise to 100% and stay there for a few minutes. That query never returns. This is valid for 7.4.1 and 7.5. It pretty much makes the REST api useless.
Users browsing this forum: Babujnik, Google [Bot], txfz and 29 guests
