hronro
RouterOS 7.5 can not import a container image file generated by BuildKit
Fri Sep 30, 2022 8:19 am
Considering the RouterOS document(https://help.mikrotik.com/docs/display/ ... nimageonPC) is suggesting using BuildKit to build the image, if we also use BuildKit to save the .tar file like this:
docker buildx build  --no-cache --platform arm64 . --output type=docker,dest=myimage.tar
The command above will generate a .tar file directly when building (in RouterOS documentation, it uses a separated command docker save to generate the .tar file). However, RouterOS can not load myimage.tar generated in this approach. (though using docker load -i myimage.tar can load it properly in docker)
Users browsing this forum: 5h4k4, almdandi, holvoetn, mkx, pe1chl, pstrauts and 58 guests
