kuiera
Ping Timed out but having internet
Fri Sep 30, 2022 8:52 am
Hello Guys,
I have an strange problem with my ISP connection.
I have internet connection but when I ping from mikrotik 8.8.8.8 or 1.1.1.1 i get timed out even that I have internet connection.
Here is the code from our Mikrotik:
# sep/30/2022 07:46:21 by RouterOS 6.49.6
# software id = RYKB-YZ4U
# model = RB750UPr2
# serial number = D1620CA1EC4A
add name=bridge1
set [ find default-name=ether1 ] comment="AM - Main"
set [ find default-name=ether2 ] comment=LAN
set [ find default-name=ether3 ] comment="IO - Backup"
/ip hotspot profile
add name=dhcp_pool0 ranges=192.168.0.2-192.168.0.254
add address-pool=dhcp_pool0 disabled=no interface=bridge1 name=dhcp1
add address=10.123.26.114/30 interface=ether1 network=10.123.26.112
add address=(my ISP Private IP) interface=ether1 network=(my ISP Private IP)
add address=192.168.0.1/24 interface=bridge1 network=192.168.0.0
add address=192.168.178.200/24 interface=ether3 network=192.168.178.0
add address=192.168.0.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.0.1
set servers=8.8.8.8,8.8.4.4
add action=drop chain=output comment="FailOver Test" disabled=yes dst-address=\
    1.0.0.1
add action=src-nat chain=srcnat comment="NAT AM" disabled=yes \
    src-address=192.168.0.0/24 to-addresses=(my ISP Private IP)
add action=masquerade chain=srcnat comment="NAT IO" out-interface=ether3
add action=masquerade chain=srcnat comment="NAT Artmotion" disabled=yes \
    out-interface=ether1
add comment=Main distance=1 gateway=192.168.178.1
add comment=Backup distance=2 gateway=10.123.26.113
add distance=1 dst-address=1.1.1.1/32 gateway=192.168.178.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/tool netwatch
add down-script="/ip route set [ find comment=Main] distance=3" host=1.1.1.1 \
    interval=10s up-script="/ip route set [ find comment=Main] distance=1"
Some help would be very apricated.
Lokamaya
Re: Ping Timed out but having internet
Fri Sep 30, 2022 12:49 pm
Login to RouterOS using IP or MacAddress?
kuiera
Mon Oct 03, 2022 9:23 am
Hello Lokamaya,
I log into Mikrotik using IP.
kuiera
Wed Sep 06, 2023 5:16 pm
Problem is solved.
The problem was that the mikrotik had an out nat rule.
anav
Thu Sep 07, 2023 4:56 pm
The problem was the inert router??? MT AI ??
Users browsing this forum: seriousblack and 62 guests
