ebench
Mikrotik Chateau 5G - Download speed slow over ethernet
Fri Sep 30, 2022 3:28 pm
I'm a novice trying to get a Mikrotik Chateau 5G router to work over ethernet.
With default config, the 5Ghz wifi works fine, but over ethernet I'm getting <1Mbps download speed, while upload speed in normal.
We've been browsing the documentation and the forums for a solution, tried to configure the device as a passthrough mode for example (my SIM card has a static public IP), but we didn't succeed.
Below is the device's config. Any help would be appreciated!
# sep/29/2022 18:08:42 by RouterOS 7.5
# software id = LJJ4-DXF5
# model = D53G-5HacD2HnD
# serial number =
add admin-mac=[sensitive information removed] auto-mac=no comment=defconf name=bridge \
    protocol-mode=none
/interface lte
set [ find default-name=lte1 ] allow-roaming=no band="" nr-band=""
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto installation=indoor mode=\
    ap-bridge ssid=MikroTik-F5BA65 wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto \
    installation=indoor mode=ap-bridge ssid=MikroTik-F5BA66 \
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
add comment=defconf interface=lte1 list=WAN
    192.168.88.0
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    established,related,untracked
    connection-state=invalid
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Europe/Paris
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    source="\r\
    \n   :if ([system leds settings get all-leds-off] = \"never\") do={\r\
    \n     /system leds settings set all-leds-off=immediate \r\
    \n   } else={\r\
    \n     /system leds settings set all-leds-off=never \r\
    \n   }\r\
    \n "
Users browsing this forum: JohnConnett and 52 guests
