miankamran7100
IP Cloud in v7 not working
Fri Sep 30, 2022 5:23 pm
Dear all,
Hope you are fine and doing well. it is stated that I have tried many times make filter rules.but Mikrotik not accessible with sn.mynetname.net in v7. But in v6 I have no problem just enable IP Clod DDNS and it is accessible remotely.
please see the attachment
Thanks & regards
jvanhambelgium
Forum Veteran
Forum Veteran
Re: IP Cloud in v7 not working
Fri Sep 30, 2022 5:57 pm
On your screenshot in the box it states "Router is behind a NAT. Remote connection might...."
If you have a NAT "upstream" (your ISP) that you cannot control, inbound connections might not be possible, nothing related to 6.x or 7.x
Your rule is exactly like mine, I run 7.5 at the moment.
IP Cloud only takes care of the "dynamic DNS" part, nothing more.
miankamran7100
Sat Oct 01, 2022 7:35 am
It dosen't metter. my Rb750 Gr3 is also behaind the and IP Cloud is working.
Suggest any other this if any
Jotne
Sat Oct 01, 2022 10:32 am
What would you do with Cloud services if the Rotuer is behind an external NAT? You will get a DNS points to your ISPs NAT.
Without a public IP Cloud would not give you much.
jvanhambelgium
Forum Veteran
Forum Veteran
Sat Oct 01, 2022 11:21 am
The rule you show is only related to the IP-cloud part, nothing to do with DNAT for making the actual inbound connection to a server/service you host.
So, if you resolve your XXXXX.mynetname.net how does it compare to any of the IP-addresses on your box ?
If you don't have any hits on that "input" UDP/15252 rule and you are sure of the config you should talk to you ISP.
Users browsing this forum: CGGXANNX, cmmike, patrikg, sebus46 and 48 guests
