ferrenbre
hAPac stuck bootloop
Fri Sep 30, 2022 5:23 pm
Hello, thanks for reading, I'm a newbie. I tried to upgrade firmware and the power went out. The firmware is corrupted and now RouterOS doesn't start because it resets again and again. I tried to use netinstall but the program doesn't detect it (i tried to reset it, changed the gateway and adapter settings, nothing worked) so I figured that that's not possible. I was wondering if there is a way using some kind of protocol to transfer the files for it to start. Thank you very much.
mkx
Re: hAPac stuck bootloop
Fri Sep 30, 2022 9:32 pm
This is exactly what netinstall does. But it is very fragile, you have to follow all the tiny details mentioned in netinstall manual. And keep trying.
Users browsing this forum: complexxL9, hazem, jaclaz and 199 guests
