Reeman
RB260GSP short circuit status
Sat Oct 01, 2022 8:53 am
Hello eveyone,
Im connecting RB260GSP to my router , when I access the switch , It shows short circuit on the port that is connected to my laptop, when changing the port the same problem still. note that Im connected to the internet without any probems. I tried different cables and the switch is upgraged to the latest version.
What is the solution?
gabacho4
Re: RB260GSP short circuit status  [SOLVED]
Sat Oct 01, 2022 9:47 am
Believe you have noticed the same thing a few of us already have. I believe this should be of help. No one has confirmed that I’m not crazy, but my belief makes sense given how PoE works other than passive.
https://forum.mikrotik.com/viewtopic.php?t=171943
Reeman
Mon Oct 03, 2022 2:07 pm
i asked Mikrotik Support, they said " this is normal as it is short and will not allow the voltage to come trough. So Yes, your devices are working as intended".
Users browsing this forum: No registered users and 15 guests
