arnaudf92
CRS326 and priority tagging bug
Sat Oct 01, 2022 10:51 am
Dear Mikrotik (devs ?) and users,
I'm currently own a CRS326 switch with ROS 7.4
I need to be able to do 802.1p tagging for selected egressing packets, based on fw or bridge filter rules.
I tried different setup with no luck :
- Set priority in mangle fw rule
- Set priority in bridge filter
- Set mark in mangle, then a bridge filter rule
- Set a DSCP (and hope that priority mapping come at rescue)
NB : a ticket support has been raised (SUP-80065), the bug confirmed, but there is no ETA on the fix.
Is it possible to plan the fix in a next release not so fr from now ?
Best regards.
arnaudf92
Re: CRS326 and priority tagging bug
Sat Oct 01, 2022 1:28 pm
Forgot to say that the issue seems to be linked to the fact that the priority set from cpu is dropped somewhere in the packet flow.
Nonetheless, additionnal tests a vlan priority can be tagged using a switch rule.
To sum up :
- vlan pri with Mangle or bridge filter : KO
- vlan pri with Switch : OK (but too few settings available)
@Mikrotik : could it be fixed pls ?
Users browsing this forum: Bing [Bot], GoogleOther [Bot], hoggins, litogorospe and 98 guests
