Techsystem
repetitive code 3 message in log section
Sat Oct 01, 2022 3:01 pm
Hello my friends..!
so what MT router want to tell me by this Reptitive message in log section..? -(as you see in the picture below )- and what code 3 mean..?
add action=passthrough chain=forward disabled=yes
add action=accept chain=input comment="allow WireGuard" disabled=yes dst-port=     protocol=udp
add action=accept chain=input comment=l2tp-ipsec disabled=yes in-interface=ether1 protocol=ipsec-esp
add action=accept chain=input comment=ipsec disabled=yes in-interface=ether1 protocol=ipsec-ah
add action=accept chain=input connection-state=established,related,untracked disabled=yes
add action=drop chain=input connection-state=invalid disabled=yes
add action=return chain=detect-ddos disabled=yes dst-limit=32,32,src-and-dst-addresses/10s
add action=add-dst-to-address-list address-list=ddos-target address-list-timeout=10m chain=detect-ddos disabled=yes
add action=add-src-to-address-list address-list=ddos-attackers address-list-timeout=10m chain=detect-ddos disabled=yes
add action=accept chain=input disabled=yes dst-address=127.0.0.1
add action=drop chain=forward comment="Drop incoming from internet which is not public IP" disabled=yes in-interface=ether1 log=yes log-prefix="! public" src-address-list=not_in_internet
rextended
Re: repetitive code 3 message in log section
Sat Oct 01, 2022 3:10 pm
the router do not tell anything, you have instructed it to log on one rule: log=yes log-prefix="! public"
and as usual with the ... we can not even check what is written after.
On that line you read only "code 3"?
Read all first, and study how ICMP works.
Techsystem
Sat Oct 01, 2022 5:04 pm
so how i can disable this log from appearing..? where is the controlling log center..?
i didn't understand what you mean by this sentence "and as usual with the..we can not even..etc"
rextended
Sat Oct 01, 2022 6:47 pm
where are log=yes log-prefix="! public" on your config?
where are the … on image?
Techsystem
Sat Oct 01, 2022 7:42 pm
moderator note: do not quote preceding post, use "post Reply".
sorry Mr rextended but it seems that i still didn't understand what you mean by that..! However, as you you see, this is all my firewall config -( in the attached file)-
and for more info i notice that when i disable all my firewall rules, this repeated message has gone, so my question what happen in my mikrotik to caue this message to appear in the log as you see in the picture..? i have this firewall rule for more than a month and no such thing appear in the log before.
Znevna
Sat Oct 01, 2022 7:53 pm
I will try to explain as simple as I can.
In pictures:
And in writing:
Techsystem
Sat Oct 01, 2022 9:00 pm
k6ccc
Sun Oct 02, 2022 6:23 am
Try learning what ICMP does, and how it works.
Here is a reference: https://www.iana.org/assignments/icmp-p ... ters.xhtml
Users browsing this forum: Bing [Bot], GoogleOther [Bot] and 38 guests
