JimiEZ
Default configuration - just can't get port forwarding to work [rb750gr3]
Sun Oct 02, 2022 1:01 pm
Hey, I know this is very very basic stuff, I've read quite a few tutorials and watched videos, but somehow I just can't get port forwarding to work on my Hex.
I went with the automatic default config and my network is as follows: 1G symmetric connection that comes through a Fiber Media Converter (bridged mode, dynamic public IP) -> into ether1 of RB750GR from there via ether2 -> TP-link 8-port dumb switch, to which everything else connects to. Wan connection works just fine and get very respectable ~900ish up/down speeds.
Here's my config:
# oct/02/2022 12:18:46 by RouterOS 6.49.6
# software id = BIWD-CH4N
# model = RB750Gr3
# serial number = CC210FD2F930
add admin-mac=XX:XX:XXX:XX auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] name=ether1_WAN
set [ find default-name=ether2 ] name=ether2_LAN
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=10.0.0.3-10.0.0.99
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=ether2_LAN
/interface detect-internet
set detect-interface-list=all
add comment=defconf interface=ether1_WAN list=WAN
add address=10.0.0.2/24 comment=defconf interface=ether2_LAN network=10.0.0.0
/ip arp
add address=10.0.0.10 comment=Server interface=bridge mac-address=\
    XX:XX:XX:XX:XX
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf disabled=no interface=ether1_WAN
/ip dhcp-server lease
add address=10.0.0.9 client-id=xxxxxxxxx mac-address=\
   xxxxxxx server=defconf
add address=10.0.0.0/24 comment=defconf gateway=10.0.0.2 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=10.0.0.2 comment=defconf name=router.lan
/ip firewall address-list
add address=cc210fd2f930.sn.mynetname.net list=WAN_list
add address=10.0.0.0/24 list=LAN_list
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=masquerade chain=srcnat comment="HAIRPIN NAT" dst-address=\
    10.0.0.0/24 src-address=10.0.0.0/24
    ipsec-policy=out,none out-interface=ether1_WAN
add action=dst-nat chain=dstnat dst-port=34343 in-interface=ether1_WAN \
    protocol=tcp to-addresses=10.0.0.9 to-ports=34343
add action=dst-nat chain=dstnat dst-port=aaa protocol=tcp to-addresses=\
    10.0.0.10 to-ports=aaa
add action=dst-nat chain=dstnat dst-port=80 in-interface=ether1_WAN protocol=\
    tcp to-addresses=10.0.0.10 to-ports=80
/ip upnp
set show-dummy-rule=no
/system clock
set time-zone-name=xxx
/system ntp client
set enabled=yes primary-ntp=162.159.200.123 secondary-ntp=188.165.138.207
/tool mac-server
/tool mac-server mac-winbox
10.0.0.10 is my home server, I've tried opening ports for HTTP and SSH, 10.0.0.9 is my desktop computer. After bumbling about, I've managed to create a functioning hairpin NAT and I'm able to access my home server via SSH through a non-standard port within LAN using my domain name, but outside connections just won't come through whatever I do.
I have a domain for the server and I'm able to access the server via the domain name within LAN but not from outside.
anav
Re: Default configuration - just can't get port forwarding to work [rb750gr3]
Mon Oct 03, 2022 12:59 am
Some reading on port forwarding - viewtopic.php?t=179343
JimiEZ
Tue Oct 11, 2022 7:43 pm
I have tried pretty much every single thing in that thread. Suggestions?
anav
Tue Oct 11, 2022 8:37 pm
Okay, post your latest config please.........
/export (minus serial number and any public IP information )
Znevna
Tue Oct 11, 2022 9:13 pm
First you have to be sure that your ISP isn't blocking that port and that your public IP is public.
Easy done sniffing traffic on your wan interface with a filter set for your desired port.
If no packets arrive, the problem isn't your config.
anav
Tue Oct 11, 2022 10:24 pm
@znevna. I am sure he has that covered cause early on in the bloated topic LOL, that is clearly stated.
JimiEZ
Thu Oct 27, 2022 11:59 pm
Life's been pretty hectic, so I've not had more than a few moments here and there to tinker with this. I'm seeing packets and traffic, but can't access anything outside LAN and port checkers tell me that my ports are not open / connection time out.
Here's my latest config:
# oct/28/2022 00:30:24 by RouterOS 7.6
# software id =
# model = RB750Gr3
# serial number =
add admin-mac=XXX auto-mac=no comment=defconf name=bridge
set [ find default-name=ether3 ] disabled=yes
set [ find default-name=ether4 ] disabled=yes
set [ find default-name=ether5 ] disabled=yes
/interface lte apn
add address-pool=dhcp interface=bridge name=defconf
/port
set 0 name=serial0
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2_LAN
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
/ipv6 settings
/interface ovpn-server server
set auth=sha1,md5
add address=10.0.0.2/24 comment=defconf interface=bridge network=10.0.0.0
/ip arp
    XXX
add address=10.0.0.3 comment=Desktop interface=bridge mac-address=\
    XXX
/ip cloud
/ip cloud advanced
set use-local-address=yes
/ip dhcp-client
add address=10.0.0.3 address-lists=LAN_list client-id=xxx \
    comment=Desktop mac-address=XXX server=defconf use-src-mac=\
    yes
add address=10.0.0.10 client-id=\
    xxx comment=Server \
    mac-address=XXX server=defconf use-src-mac=yes
/ip dns static
add address=[mydomain that resolves correctly to my dynamic public ip] list=WAN_list
    invalid
add action=accept chain=input in-interface-list=LAN
add action=drop chain=input
    "defconf: accept to local loopback (for CAPsMAN)" disabled=yes \
    dst-address=127.0.0.1
    disabled=yes in-interface-list=!LAN
    disabled=yes ipsec-policy=in,ipsec
    disabled=yes ipsec-policy=out,ipsec
    established,related,untracked in-interface-list=WAN
    connection-state=invalid log=yes log-prefix=inva
add action=accept chain=forward comment="Allow internet traffic" \
    in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="Port forward test" \
    connection-nat-state=dstnat
add action=dst-nat chain=dstnat comment=HTTP dst-address-list=WAN_list \
    dst-port=80 protocol=tcp to-addresses=10.0.0.10
add action=dst-nat chain=dstnat comment=SSH dst-address-list=WAN_list \
    dst-port=220 protocol=tcp to-addresses=10.0.0.10 to-ports=220
add action=dst-nat chain=dstnat comment="qBittorrent TCP" dst-address-list=\
    WAN_list dst-port=34343 protocol=tcp to-addresses=10.0.0.3 to-ports=34343
add action=dst-nat chain=dstnat comment="qBittorrent UDP" dst-address-list=\
    WAN_list dst-port=34343 protocol=udp to-addresses=10.0.0.3 to-ports=34343
/ip service
set www port=81
set ssh port=666
/ip upnp interfaces
add interface=ether1_WAN type=external
add interface=bridge type=internal
/system clock
set time-zone-name=XXX
/system ntp client
set enabled=yes
/system ntp client servers
add address=162.159.200.123
add address=188.165.138.207
/tool mac-server
As mentioned previously, I can access SSH and HTTP on my server at 10.0.0.10 and my domain name over LAN just fine, and seems that my desktop torrent client is getting plenty of traffic over at UDP, but very little over TCP (both are enabled in the client):
(I just realized that I took this screenshot right after router reboot so it might not actually be that informative)
Yes, I'm absolutely sure that my public IP is public and the router knows it. I've tried multiple ways of setting up dst-nat, with interface, interface-list, giving it my current public IP to dest. address etc. Absolutely nothing seems to work.
Sob
Fri Oct 28, 2022 12:31 am
This rule should not have in-interface-list=WAN (but it's not breaking port forwarding thanks to another further rule):
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=established,related,untracked in-interface-list=WAN
Actually, there's nothing I can see that would break port forwarding. You can try this to see more details about what's going on. Use your ssh port, it will have least of unwanted traffic, since it's non-standard.
anav
Fri Oct 28, 2022 12:34 am
** problem may stem from a forward chain rule (para 5) **
edit: I see sob has already answered this but do make the changes as the format is wrong.......
(1) Change this to NONE, no one uses it.
(2) For testing purposes DISABLE this line in your configuration since it relates to the server.
/ip arp
XXX
(3) In addition if you have anything set here that is extra (besides making the server a static LANIP) remove it.
(4) Your Input chain rules needs a smidge of cleanup. (order, duplication etc.)
Please find a fixed version.
{Default rules}
invalid
{Admin entered rules}
add action=drop chain=input Comment="drop all else"
(5) Same deal on forward chain.............. since not doing ipsec can dispense with the xtra stuff. Also I think the issue may be caused by an addition you made to the default rule that needs to be removed!!
Cleaned UP Version.........
{Default rules}
connection-state=invalid log=yes log-prefix=invalid
add action=accept chain=forward comment="allow port forwarding" \
add action=drop chain=forward comment="drop all else"
(6) Good hairpin nat rule.
(7) Disable UPNP connectivity should not be required.
(8) WHY or WHY are you running an http server and an SSH server for what purposes??
Just saying that you are inviting TONS of hacking attempts by doing so.
If you need access to the router use VPN like wireguard for example>
Also there is SSH built into the router, why port forward to your own instance, makes no sense to me??
State the requirements and maybe there are better ways of accomplishing same!
Sob
Fri Oct 28, 2022 1:41 am
About (8) ... Web server is great when one wants to host some web page. In fact, not running web server is major obstacle for doing some hosting. I have one (well, more), don't you? It's great thing for networking enthusiast! And SSH, it could be that you want to access some machine that's not router, and then connecting to that machine works better than connecting to router. ;)
anav
Fri Oct 28, 2022 3:21 am
Yes all true but the risks of opening ports on the router to god knows what is IMHO not the better option.
One can easily host a website at a third party location and setup or even rent a server and do it there........
I for one would never have any port forwardings to a server but if I did you can be sure it would be limited to specific source addresses.
Sob
Fri Oct 28, 2022 5:18 am
But where's the fun in that? If I now have faster connectivity at home, than the whole country used to have (and it's not anything special, costs next to nothing), server can be device that eats 5 Watts tops and it's so small that I could lose it if it wasn't connected to cable, ... why would I want external hosting? I mean, if it's some small non-critical hobby thing, and assuming that I like to play with such things. :)
anav
Fri Oct 28, 2022 2:17 pm
At least you are being honest! :-)
Sob
Fri Oct 28, 2022 5:49 pm
It's my (not so much) secret recipe for success. Play with it as often as possible, don't be afraid to experiment, but keep it pleasant to not get discouraged. Eventually you should become good at it. Not necessarily limited to routers and stuff.
anav
Fri Oct 28, 2022 5:52 pm
I hope someone is writing down these life lessons!! Sounds like an 11th commandment too. :-0
JimiEZ
Thu Nov 03, 2022 3:25 pm
Thank you anav and Sob both for your help. I was really losing my mind with this issue. I did everything you suggested and then went as far as completely resetting the router a couple of times and trying both new autoconfig and doing a minimal setup manually.
However, in the end, turned out that the issue all along was that my new ISP is actually blocking all incoming <1900 UDP connections from their end by default and only allowing a small handful of TCP ports in the single digit range. I should have suspected something like that when it started seeming like UDP port forwards were working fine but TCP ones weren't. However, during the 25+ years I've been paying for an internet connection, this is the first time I've ran across this issue, so it never even crossed my mind as a possibility. Why on earth would you sell a 1G symmetric fiber connection, only to hamper it with crap like this by default!? Oh well, at least I managed to get an unrestricted connection with a single phone call to their tech support and guess I learned quite a bit about RouterOS firewalls too!
As to why I have a home server with HTTP and SSH running? Well, like Sob, I like to tinker with that kind of stuff and use SSH for running an IRC client etc.Keeping the system fairly restricted, up to date and using software like fail2ban and I haven't really had any issues in the well over a decade I've been running one.
Users browsing this forum: 0xAA55, haedertowfeq, Shambler and 56 guests
