steen
RouterOS 7.5 where is UPS?
Sun Oct 02, 2022 7:54 pm
Hello folks!
We recently upgraded several devices to RouterOS 7.5 from 6.x. We had several APCUPS:es using USB connected.
Where is UPS, am I missing something ?
I can not find UPS settings, we no longer have our UPS:es monitored ad devices using RouterOS 7.5.
Thank you in advance!
I anser myself, it was in extra packages... how stupid :-)
Anyhow, the APCUPS was not detected and beneath the system ups menu only serial port could be added, there is nothing in the logs. Maybe it only works with serial ports, that is nothing I to use. (Raspberry pi detected the apcups using the same cables.)
eddieb
Re: RouterOS 7.5 where is UPS?
Sun Oct 02, 2022 10:04 pm
Looks like I could have made this posting ...
I tried to get the USB port of my CCR1009 to regognize the APCUPS.
No luck, nothing on USB, not even the WOOBM stick from MT itself
Running 7.5, nothing in logs, nothing on USB
anyone got this working ?
(RPi3 works fine with same cables)
steen
Sun Oct 02, 2022 10:29 pm
I have exactly the same situation (CCD1009, CCR1016 and CRS125),
tried APCUPS first directly and via a small USB hub, no luck, tried WOOBM stick no luck. Nothing in logs.
Then I connected a flash disk to the USB port, and that was working it was detected cleanly, I formatted it and put a lot of files on it, all working and fast with little CPU consumed.
So I guess we have a situation here... RoS7.5 and USB devices like WOOBM and APCUPS.
eddieb
Sun Oct 02, 2022 10:38 pm
Guess I found some diff...
CCR1009 (tile)
/system/routerboard/usb> print
CRS125 (mipsbe)
usb-mode: automatic
bootstrap: device-mode
on the tile there is "nothing" ...
SUP-93986 created
eddieb
Mon Oct 03, 2022 1:17 pm
response from support ...
Thank you for contacting MikroTik Support.
We are aware of the issue and will try to resolve it in future releases, unfortunately, I cannot provide you with any ETA for possible fixes.
Best regards
eddieb
Wed Oct 05, 2022 2:56 pm
not in the changelog for 7.6RC1
Users browsing this forum: Bing [Bot], hast, Maggiore81 and 97 guests
