adian009
RB5009 7.6beta10 Can't install container package
Mon Oct 03, 2022 6:58 am
After enabling device-mode/update container=yes then clicking Reset, I can now print and see container is enabled. Then I read that I needed the Extra Package, so I downloaded it for ARM 7.6beta10, uploaded the NPK to root and have restarted twice. I do not see the Container menu, the Container NPK file is gone from root and I don't see any errors.
Has anyone been able to install and enable this?
Znevna
Re: RB5009 7.6beta10 Can't install container package  [SOLVED]
Mon Oct 03, 2022 7:00 am
RB5009 is arm64, not arm.
adian009
Mon Oct 03, 2022 7:04 am
Wow I need some sleep, THANKS!
Users browsing this forum: akakua, bdivrik and 193 guests
