techresponsematt
Can't add a route with a PPPoE client as the gateway in RouterOS 7.5
Mon Oct 03, 2022 3:48 pm
Hi all,
I am trying to set up routes with PPPoE clients as gateways (for multi-WAN) on 7.5 but the router will not accept the routes.
If I try to do this through WinBox, the route saves but the gateway box changes to being blank.
If I use the terminal, I get:
[admin@MikroTik] > /ip route add dst-address=0.0.0.0/0 gateway=tl203@a.1@main
invalid or unexpected argument base
[admin@MikroTik] > /ip route add dst-address=0.0.0.0/0 gateway=tl203@a.1@main dist
ance=2
ance=2 routing-table=main
[admin@MikroTik] > /ip route add  gateway=tl203@a.1@main distance=2
[admin@MikroTik] > /ip route add  gateway=tl203@a.1 distance=2
If I try to do it by copying the default route, which works, I get an error "Error in Gateway - address expected!" when I click OK.
Is there some way around this?...
techresponsematt
Re: Can't add a route with a PPPoE client as the gateway in RouterOS 7.5
Mon Oct 03, 2022 6:17 pm
Discovered that this works if the gateway doesn't have an @ in the name!
Users browsing this forum: aferreira, Bing [Bot], FurfangosFrigyes and 172 guests
