lpjerry
Cannot access RB4011 outside of bridge interface
Mon Oct 03, 2022 8:56 pm
Dear Forum,
So the other day when I was playing with my RB4011 I managed to disable my bridge1 interface and lock out from my router.
Luckily, I was able to dial in via VPN and solve the issue.
After this incident I decided to follow the suggestions found in this forum and created an ethernet interface (eth6-emerg) outside my bridge.
However after connecting this interface to my computer I cannot access the router via winbox nor via SSH, it's says wrong username/password which is clearly not true.
(The user/pass is saved in winbox).
I left out the firewall settings on purpose because I already tried disabling all of them, but still cannot connect to router.
Could you please tell me what I'm missing?
Many thanks,
Cheers,
Gerhard
Here is my config:
# oct/03/2022 19:20:30 by RouterOS 7.5
# model = RB4011iGS+
add igmp-snooping=yes name=bridge1 priority=0x1000
set [ find default-name=sfp-sfpplus1 ] l2mtu=1592 name=SFP+ rx-flow-control=\
    auto tx-flow-control=auto
set [ find default-name=ether1 ] name=WAN rx-flow-control=auto \
set [ find default-name=ether2 ] disabled=yes
set [ find default-name=ether3 ] disabled=yes
set [ find default-name=ether4 ] disabled=yes
set [ find default-name=ether5 ] disabled=yes
set [ find default-name=ether6 ] name=ether6-emerg
set [ find default-name=ether7 ] disabled=yes
set [ find default-name=ether8 ] disabled=yes
set [ find default-name=ether9 ] rx-flow-control=auto tx-flow-control=auto
set [ find default-name=ether10 ] poe-out=off rx-flow-control=auto \
set WAN disabled=no
set ether2 disabled=no
set ether3 disabled=no
set ether4 disabled=no
set SFP+ disabled=no
/interface vlan
add interface=bridge1 name=vlan20 vlan-id=20
add interface=bridge1 name=vlan107 vlan-id=107
/interface bonding
add mode=802.3ad name="US-24 LACP" slaves=ether9,ether10
add exclude=dynamic name=discover
add exclude=dynamic include=all name=internet
add name=LAN_pool ranges=10.0.0.50-10.0.0.250
add name=vlan107_pool ranges=10.0.107.50-10.0.107.98
add name=vlan20_pool ranges=10.0.20.50-10.0.20.100
add name=emerg_pool ranges=10.10.10.2-10.10.10.10
add address-pool=LAN_pool interface=bridge1 lease-time=6h name="LAN dhcp"
add address-pool=vlan107_pool interface=vlan107 lease-time=6h name="IoT dhcp"
add address-pool=vlan20_pool interface=vlan20 lease-time=6h name="Cam dhcp"
add address-pool=emerg_pool interface=ether6-emerg lease-time=1h name=\
    "Emergency DHCP"
add bridge=bridge1 fast-leave=yes ingress-filtering=no interface=SFP+
add bridge=bridge1 fast-leave=yes ingress-filtering=no interface="US-24 LACP"
set discover-interface-list=none
add address=10.0.0.1/24 comment=LAN interface=bridge1 network=10.0.0.0
add address=10.0.107.1/24 comment=IoT interface=vlan107 network=10.0.107.0
add address=10.0.20.1/24 comment=Cameras interface=vlan20 network=10.0.20.0
add address=10.10.10.1/28 comment="Emergecy access" interface=ether6-emerg \
    network=10.10.10.0
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
/ip service
set telnet disabled=yes
set www disabled=yes
set ssh address=10.0.0.0/24,10.0.66.0/27,10.10.10.0/28
set api disabled=yes
set winbox address=10.0.0.0/24,10.0.66.0/27,10.10.10.0/28
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/system identity
set name=RB4011
/system routerboard settings
set auto-upgrade=yes
/system watchdog
set automatic-supout=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
mkx
Re: Cannot access RB4011 outside of bridge interface
Mon Oct 03, 2022 9:54 pm
I don't really know why device is rejecting your password used via ssh or winbox. Is it acting the same way when connecting via other subnets (LAN or VLAN 107 or VLAN 20)?
Personally I have high regard for MT's possibility to connect to device via MAC, which largely bypasses IP firewall (and thus one has to enable it after thorough consideration). Since you're dedicating a physical interface to out-of-band management, you may want to consider changing the following settings:
/tool mac-server
Sob
Mon Oct 03, 2022 11:02 pm
Are there perhaps some dstnat rules that could be sending those connection attempts to another device?
anav
Tue Oct 04, 2022 12:18 am
Do it the right way.........
viewtopic.php?t=181718
lpjerry
Re: Cannot access RB4011 outside of bridge interface  [SOLVED]
Tue Oct 04, 2022 10:48 pm
Thanks everyone!
So the problem was that I forgot to add the new subnet into System/Users/Allowed Address field!
Cheers,
Gerhard
lpjerry
Tue Oct 04, 2022 10:50 pm
Also thank you anav for linking your post here! I found very helpful infos and practices in it!
Users browsing this forum: erlinden, tarfox and 154 guests
