joshhboss
NetPower16 P - Enough power with 96W
Tue Oct 04, 2022 5:29 am
I was hoping to use this device for events. But how many Aps Would I actually be able to do with this? is 96Watts Enough. What if I wanted to actually use all 16 ports on this device. Is that possible. to Get 30Watts per port? or even 15?
mkx
Re: NetPower16 P - Enough power with 96W
Tue Oct 04, 2022 8:41 am
Why don't you do the math? Product brochure has some data about PoE out capacity (e.g. 2.8 A (1.4 A per 8port group, max 0.6 A per port) for 30+V). If you go for 54V PA, this means max 32W per port (minus losses on UTP cable towards AP). Etc.
joshhboss
Tue Oct 04, 2022 2:50 pm
Would this switch fall into CRS3X series of switches that support Bridge Hardware Offloading. I know the articles says CRS3XX series of switches but I didnt see it mentioned in the models section of that page.
biomesh
Long time Member
Long time Member
Tue Oct 04, 2022 4:23 pm
Yes, look at the different docs for CRS318-16P-2S+. That is the full model number.
Users browsing this forum: No registered users and 88 guests
