joshhboss
Netpower16 p and Veracity Power supply
Tue Oct 04, 2022 6:57 am
I was considering purchasing this.. to power the 16p. Mainly because it looks easier for me to install then the Mikrotik Device MTP250-53V47-OD.
I posted a picture of the power adapter. Any insight would be greatly appreciated. I am only really considering putting at/af devices on it. For 24v ill use injectors if that makes it easier and safer.
mkx
Re: Netpower16 p and Veracity Power supply
Tue Oct 04, 2022 8:30 am
It should be fine as long as it follows the Mikrotik plug specifications: viewtopic.php?t=54024
Users browsing this forum: Google [Bot] and 131 guests
