sgtourism176
public ip > local ip Help me!
Tue Oct 04, 2022 10:42 am
I have a situation that I need to figure out quickly. :?:
I have a public IP on int WAN=65.123.x.x
I have a local IP on int LAN=10.59.1.64
I need to set up something that will allow an outside IP to tunnel thru my network to the LAN ip while retaining all my other connections...
I am affraid of creating a src + dst rule in fear that I might route all traffic to that box and bring my network down.
Can you guys give me a solution!? I need step by step on this, this is my first time ever dealing with this!!
Thanks!
::More Specs on Setup::
This is what I need to see happen...
Remote office (24.29.x.x)
T1 (65.123.x.x)
MT (10.59.1.1)
AP (10.59.1.9)
CPE (10.59.1.25)
*PIX501* (10.59.1.64)
How is this done? Thanks
Saigontourism
Sob
Re: public ip > local ip Help me!
Wed Oct 05, 2022 3:15 am
Try different words and more details, so far it doesn't seem exactly clear. If you want to simply access some ports on 10.59.1.64 from 24.29.x.x (and only from there), dstnat should be enough, e.g.:
add chain=dstnat dst-address=65.123.x.x protocol=<tcp/udp> dst-port=<number(s)> src-address=24.29.x.x action=dst-nat to-addresses=10.59.1.64
Users browsing this forum: Bing [Bot], techcomtecnico and 126 guests
