LTEjunkie
Netinstall .. .
Tue Oct 04, 2022 10:59 pm
Hi
okay I have two problems ..
I have a RBSXTR .. forgot the password and while the antenna was on pressed the mode button instead of reset.. now the freaking thing stopped working.
So what happens
- power works ..
- power on give the three flashes .. nothing else .. after a while the LEDS for antenna reception flash briefly ..
- network interface on the laptop has link light and green light .. the antenna only green light on the network interface
-switched off the firewall .. nada ... no difference/
The net install though ( windows V10) does not look the same as the examples.. I have configured everything correctly, I can select the firmware file but the antenna never comes up .. and I cannot see my C drive on the top screen either ?
wits end is the only description ..
anav
Re: Netinstall .. .
Tue Oct 04, 2022 11:02 pm
Please read para H. - viewtopic.php?t=182373
Users browsing this forum: xrlls and 43 guests
