tdeak
IP Service Winbox cmd line new entry
Wed Oct 05, 2022 8:46 am
Dear Members,
I'm trying to build a script which resolves a dyndns address store it on a variable and add it to NEW allowed address (and removes the old one) from IP Service / Winbox / allowed address.
I have the resolver:
:global myip [:resolve domain-name=myip.selfip.net server=8.8.8.8]
I can add it to allowed address with:
 /ip service/set winbox address=$myip
But my problem is that this replaces the existing records and not addind a new line.
Is anybody know some cmdline switch/parameter to do this job?
loloski
Re: IP Service Winbox cmd line new entry
Wed Oct 05, 2022 9:50 am
there is no direct way you have to put it in an array, this is not the answer you are looking for but it's a step in right direction this command will add this two address from the list
/ip service/set address=1.1.1.2,1.1.1.1 winbox
loloski
Wed Oct 05, 2022 10:40 am
i'm not a scripting guru but i put a stab on it, here is the little code to do it
:global address [/ip service/get [find name="winbox" value-name]]
:global list [:pick $address 1]
:set $list ($list,$myip)
/ip service/set address=$list winbox
tdeak
Wed Oct 05, 2022 12:35 pm
Hi loloski,
thanks for your effort. After some tweak the script working but unfortunately still replace the line to only one (the variable).
Here is the script so far:
:global address [/ip service find name="winbox" value-name]
/ip service set address=$list winbox
So this is working but still replace the whole address list. I'm trying now to manipulate further..
edit: problem will be somewhere in "winbox" value. Unfortunately somewhere the syntax will be the issue to read correctly the value of "Available From" table.
rextended
Wed Oct 05, 2022 1:10 pm
Only the simpler things are clearly readable.
I'll be back in a moment with the solution(s)
rextended
Re: IP Service Winbox cmd line new entry  [SOLVED]
Wed Oct 05, 2022 1:19 pm
1st mode: is knowed already the allowed IPs:
:local always   "0.0.0.0/0,192.168.88.0/24"
:local dnsname  "one.one.one.one"
:local resolver "8.8.8.8"
:global resolved "127.0.0.1"
[:execute ":global resolved;:set resolved [:resolve $dnsname server=$resolver]"]
:delay 2s
/ip service set winbox address="$always,$resolved"
rextended
Wed Oct 05, 2022 1:28 pm
2nd way: idiocy, add other IPs without removing the unused ones.
:local dnsname  "www.mikrotik.com"
:delay 2s
/ip service
:local actualips [get winbox address]
set winbox address=($actualips,$resolved)
Users browsing this forum: masrandoo, mkx, nichky, varkey, xekonin and 11 guests
