geebee63
Express VPN OVPN on mikrotik
Wed Oct 05, 2022 6:10 pm
Has anyone been able to sucessfully connect to expressVPN servers using ovpn?
Also, does Mikrotik support TLS v1.3?
I have tried so many times to connect but it says TLS failed.
aah
Re: Express VPN OVPN on mikrotik
Fri Oct 21, 2022 9:41 am
Did you ever find a solution?
rndm
Tue Nov 29, 2022 12:33 pm
Any updates on this from Mikrotik dev team?
Auth by login and password not working :(
Omid007
Wed Dec 07, 2022 3:13 pm
As express VPN is not supporting L2TP&PPTP protocols anymore, we need a solution to use open VPN client on Mikrotik, Express VPN deleted Mikrotik from supported routers so i think there is no solution right now, I discussed it with EXpresss VPN supports many times and they couldn't help.
I tried to set up Express VPN open VPN manually, the link is established but it doesn't connect.
we really need Mikrotik's supports.
tabraham
Thu Mar 23, 2023 12:04 pm
Anyone any update? I am also having the TLS handshake error for OVPN at ROS7
anav
Thu Mar 23, 2023 12:36 pm
Use Wireguard or zerotier
linus
Thu Jun 22, 2023 3:31 am
Hi, I am looking for some guidance on how to set up ExpressVPN on my Mikrotik router. Does anyone have a working config that they can share with me? Thank you for your help.
Sonnenschein
Sat Sep 30, 2023 5:37 am
Hi guys!
Has anyone found a way to connect VPN Express on their Mikrotik?
Users browsing this forum: Bing [Bot], GoogleOther [Bot] and 16 guests
