Is there any problem in the firmware with vlan filtering per bridge?
Mikrotik 4011 os 7.5
I would like one of the vlans to be available on both the router and the connected switch ports
when I turn on
add ingress-filtering = no name = bridge1 vlan-filtering = yes
the vlan port on the router on the switch is not working
when I turn off
add name = bridge1
works on switch and vlan does not work on router
add ingress-filtering=no name=bridge1 vlan-filtering=yes
/interface vlan
add interface=bridge1 name=vlan10 vlan-id=10
add interface=bridge1 name=vlan20 vlan-id=20
add name=dhcp_pool1 ranges=192.168.10.2-192.168.10.254
add name=dhcp_pool2 ranges=192.168.20.2-192.168.20.254
add address-pool=dhcp_pool1 interface=vlan10 name=dhcp1
add address-pool=dhcp_pool2 interface=vlan20 name=dhcp2
add bridge=bridge1 ingress-filtering=no interface=ether2 pvid=10
add bridge=bridge1 ingress-filtering=no interface=ether3 pvid=20
add bridge=bridge1 ingress-filtering=no interface=ether4
/interface bridge vlan
add bridge=bridge1 tagged=bridge1 untagged=ether2 vlan-ids=10
add bridge=bridge1 tagged=bridge1 untagged=ether3 vlan-ids=20
add bridge=bridge1 tagged=bridge1 untagged=ether2,ether3 vlan-ids=1
add address=192.168.10.1/24 interface=vlan10 network=192.168.10.0
add address=192.168.20.1/24 interface=vlan20 network=192.168.20.0
add address=192.168.10.0/24 gateway=192.168.10.1
add address=192.168.20.0/24 gateway=192.168.20.1
