hofi76
l2tp with ipsec site-to-site between 2 mikrotik router
Thu Oct 06, 2022 3:07 pm
I configured a mikrotik as l2tp server with ipsec and an other one as l2tp client.
If the ipsec is disabled all looks fine.
[admin@Router1] /ip/ipsec/active-peers> /ppp/active/print
Columns: NAME, SERVICE, CALLER-ID, ADDRESS, UPTIME
# NAME   SERVICE  CALLER-ID    ADDRESS        UPTIME
0 user1  l2tp     10.36.6.205  172.16.16.101  29s
If I enable the ipsec, the ipsec looks fine but the ppp connection did not operate The status is link established
[admin@Router1] /ip/ipsec/active-peers> print
Flags: R - RESPONDER
Columns: STATE, UPTIME, PH2-TOTAL, REMOTE-ADDRESS
#    STATE        UPTIME  PH2-TOTAL  REMOTE-ADDRESS
;;; l2tp-in-server
0 R  established  22s             1  10.36.6.205
Any idea why?
Server side config:
/ip ipsec profile
set [ find default=yes ] dh-group=modp2048 enc-algorithm=aes-256
/ppp profile
add change-tcp-mss=yes local-address=172.16.16.1 name=HQ-R1 remote-address=172.16.16.101 use-encryption=yes
add change-tcp-mss=yes local-address=172.16.16.2 name=HQ-R2 remote-address=172.16.16.102 use-encryption=yes
/interface l2tp-server server
set authentication=mschap2 enabled=yes ipsec-secret=*SECRET* one-session-per-host=yes use-ipsec=yes
/ppp secret
add name=user1 password=*pw* profile=HQ-R1 service=l2tp
add name=user2 password=-pw* profile=HQ-R2 service=l2tp
Client side config:
/ip ipsec profile
/ppp profile
add change-tcp-mss=yes local-address=172.16.16.101 name=R1-HQ remote-address=172.16.16.1 use-encryption=yes
/interface l2tp-client
add allow=mschap2 connect-to=10.36.6.204 disabled=no ipsec-secret=*SECRET* name=R1-HQ-l2tp password=*pw* profile=R1-HQ use-ipsec=yes user=user1
[/code]
karlisi
Re: l2tp with ipsec site-to-site between 2 mikrotik router
Thu Oct 06, 2022 3:56 pm
I suppose, there is more configuration, especially on server side. Because you don't posted it, this can be only guess, but perhaps there is no ipsec-esp (50) protocol allowed in input chain of server's firewall?
hofi76
Thu Oct 06, 2022 5:28 pm
At the moment it is still in test environment so no firewall configured
See the full config of the l2tp Server maybe you will find the mistake
HQ
add name=bridge1
set [ find default-name=ether1 ] name=WAN
/interface eoip
add arp=proxy-arp local-address=172.16.16.1 mac-address=02:EA:F9:52:59:AE \
    name=HQ-R1-EOIP remote-address=172.16.16.101 tunnel-id=10
add arp=proxy-arp local-address=172.16.16.2 mac-address=02:EA:F9:52:59:AE \
    name=HQ-R2-EOIP remote-address=172.16.16.102 tunnel-id=20
/ip ipsec profile
add dh-group=modp2048 enc-algorithm=aes-256 name=l2tp_ipsec
add name=dhcp_pool1 ranges=192.168.76.1-192.168.76.200
add address-pool=dhcp_pool1 interface=bridge1 name=dhcp1
/port
set 0 name=serial0
/ppp profile
add change-tcp-mss=yes local-address=172.16.16.1 name=HQ-R1 remote-address=\
add change-tcp-mss=yes local-address=172.16.16.2 name=HQ-R2 remote-address=\
add bridge=bridge1 interface=HQ-R1-EOIP
add bridge=bridge1 interface=HQ-R2-EOIP
set authentication=mschap2 default-profile=HQ-R1 enabled=yes ipsec-secret=\
add address=192.168.76.254/22 interface=bridge1 network=192.168.76.0
/ip dhcp-client
add interface=WAN
add address=192.168.76.0/22 gateway=192.168.76.254
add action=masquerade chain=srcnat dst-address=0.0.0.0/0 src-address=\
    192.168.76.0/22
/ppp profile
set *0 local-address=172.16.16.101 remote-address=*1
/ppp secret
add name=user1 password=*PW* profile=HQ-R1 service=l2tp
add name=user2 password=*PW* profile=HQ-R2 service=l2tp
/system identity
set name=Router1
/system ntp client
set enabled=yes
/system ntp client servers
add address=10.36.2.11
Users browsing this forum: djvabe, kokoboko and 126 guests
