I am trying to use a hAP AC Lite to achieve the following:
Part 1:
wlan 1 > Connect in Station Mode to an existing WiFi
Ether2-5 > Allowed to use wlan1 as a gateway to the internet
Part 2:
wlan2 > Broadcast Open WiFi as a hotspot
Part 1 is all working as expected and there are no issues
Part 2 is driving me mad, I think because I'd like the following to happen:
Join wlan2 Open WiFi > Auto-login > redirect to web server connected to Ether2
At the moment, the hotspot advertises (but says No Internet) and while I can join the hotspot I don't get any re-direction. In addition, if join and then attempt to manually reach the web server on Ether2 it tells me the connection is refused, or basically never loads
ANY help with this would be massively appreciated before I pull all of my hair out
Lenny
