abhsek
Couldn't remove simple queue - not permitted
Thu Oct 06, 2022 9:35 pm
I was trying to remove a simple que manually, and I get a error "couldn't remove simple queue - not permitted"
I was removing the simple que which was generated automatically when a pptp user or hospot trail user log's in.
On my RB750GR3 i was easily able to remove the simple ques, same way, but on my new RB5009 i cannot remove.
Please help me with guidance. Thanks.
(Screenshot Attached)
woronti
Re: Couldn't remove simple queue - not permitted
Wed Oct 12, 2022 4:36 pm
I have the same problem too. Is it a bug or something?
normis
Thu Oct 13, 2022 8:39 am
Dynamic elements are not meant to be removed. Leave it there.
rexsllemel
Fri Nov 25, 2022 10:39 am
I have to manually remove the simple queue because a user from hotspot cannot login
In my case, it says "Can't remove dynamic object"
I guess this is a bug. When user logout, the queues did not removed automatically.
irsup
Sun Dec 25, 2022 9:05 am
I have a similar problem, every few hours a number of dynamic queues become red and invalid and Mikrotik cannot clear them.
And it makes users unable to connect again.
I use CHR 7.6.
please guide me
mrysoft
Tue Jun 27, 2023 10:21 am
I have a similar problem, every few hours a number of dynamic queues (sstp+l2tp+pptp+ovpn) become red and invalid and Mikrotik cannot clear them.
And I have to reboot the router to fix the problem After restarting the router, they connect without any problem
I use x86 7.9.2
please guide me
Users browsing this forum: benlg, jaclaz and 188 guests
