LifeGame
IPSec
Mon Oct 10, 2022 11:59 am
Hi ..
Mikrotik LAN : 10.10.5.1/24
Mikrotik WAN : Static
IPSec Policy
Source Address : 10.10.5.0/24
Dest. Address : 0.0.0.0/0
With this policy ipsec works as i want. I can route traffic with nat policy..
When ipsec policy enable;
- I cant connect mikrotik from 10.10.5.1.. i need to use mac adress for connection.
- Mikrotik DNS server is not working.
When I disable ipsec policy, everything goes back to normal... As far as I understand, my problem is 0.0.0.0 in ipsec policy. But i need this for routing.
How can i fix this ?
Sob
Re: IPSec  [SOLVED]
Mon Oct 10, 2022 3:49 pm
You need to exclude this traffic, add another policy before existing one, with both src and dst 10.10.5.0/24 and action set to none.
LifeGame
Re: IPSec
Mon Oct 10, 2022 4:01 pm
You are king !!!
/ip ipsec policy
add action=none dst-address=10.10.5.0/24 src-address=10.10.5.0/24
add dst-address=0.0.0.0/0 level=unique peer=onurgroup proposal=IPSec_Crypto \
src-address=10.10.5.0/24 tunnel=yes
add action=accept chain=srcnat disabled=yes dst-address=0.0.0.0/0 \
Users browsing this forum: gigabyte091 and 38 guests
