eldoncito2019
Save .rsc file in subfolder
Mon Oct 10, 2022 6:18 pm
Guys,
I'm trying to save a "rsc" backup to a subfolder, and I can't do it, here's my script
:local name  "750GL(SERVER)"
:local fname "RB"
:local backupname "$fname$name"
/ip smb shares
   :local temp [get [find default=yes] directory]
   set [find default=yes] directory=$fname
   set [find default=yes] directory=$temp
   export compact file=$backupname
Thanks for the help friends.
EL DONCITO.
rextended
Re: Save .rsc file in subfolder
Mon Oct 10, 2022 6:20 pm
but why don't you ask in the same topic where you copied the script from, that you then modified as you like, removing needed parts?
viewtopic.php?t=189823#p961045
Users browsing this forum: No registered users and 20 guests
