massinia
CAPsMAN local forwarding or bridge?
Wed Oct 12, 2022 4:39 pm
Hi, sorry for the trivial question ... :roll:
Three cAP AC will finally arrive soon and I am trying to figure out how to configure CAPsMAN.
There are no VLANs and all wireless clients connected to the cAPs will have to communicate with each other, so I have to use the bridge, right?
If I use Local Forwarding and Client To Client forwarding instead, wireless clients connected in cAP 1 cannot communicate with those connected in cAP 2, did I get it right?
mkx
Re: CAPsMAN local forwarding or bridge?  [SOLVED]
Wed Oct 12, 2022 8:08 pm
... so I have to use the bridge, right?
Right. But not for the reasons you mentioned. It's because you want CAP clients to communicate with clients of the other CAP or LAN servers and transparent communication between any two interfaces (ethernet, wireless, ...) goes via a bridge.
Wrong.
If you don't select client to client forwarding, then clients of same AP won't be able to communicate with each other (has nothing to do with other clients of other APs).
If you don't select local forwarding, then all traffic of all wireless clients (of all APs provisioned with same datapath setup) will pass CAPsMAN, even if destined to another AP which is connected to same LAN or any other LAN member (e.g. wired NAS).
massinia
Wed Oct 12, 2022 8:41 pm
Thanks for your help :D
One last thing escapes me, what's the point of this configuration?
Why use bridge and local forwarding together?
I see it in many youtube guides.
massinia
Thu Oct 13, 2022 7:26 pm
I have tried and it is definitely a wrong configuration.
The local forwarding setting takes priority over the bridge setting.
It's all clear now, thanks again for your help.
Users browsing this forum: No registered users and 67 guests
