eldoncito2019
Last link up time
Wed Oct 12, 2022 10:58 pm
Guys,
How do I get the "LAST LINK UP TIME"?
EL DONCITO.
ingdaka
Trainer
Trainer
Re: Last link up time
Thu Oct 13, 2022 12:58 am
Where do you want to get it?! You see it on interface...
Jotne
Thu Oct 13, 2022 7:55 am
That would I also like to know.
You can see it in Winbox, but not on command line:
[admin@router1] /interface/ethernet> print detail
Flags: X - disabled, R - running; S - slave
 0 R  ;;; WAN
      name="ether1" default-name="ether1" mtu=1500 l2mtu=1596 mac-address=6C:3B:6B:XX:34:3E orig-mac-address=6C:3B:6B:XX:34:3E arp=enabled
      arp-timeout=auto loop-protect=default loop-protect-status=off loop-protect-send-interval=5s loop-protect-disable-time=5m
      auto-negotiation=yes advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full full-duplex=yes tx-flow-control=off
      rx-flow-control=off speed=1Gbps bandwidth=unlimited/unlimited switch=switch1
[admin@router1] > /interface/ethernet/print stats-detail
 0 R  ;;; WAN
      name="ether1" driver-rx-byte=523 741 144 232 driver-rx-packet=625 747 504 driver-tx-byte=56 525 254 942 driver-tx-packet=261 702 331
      rx-bytes=527 658 033 486 rx-packet=624 070 976 rx-too-short=0 rx-64=59 788 950 rx-65-127=143 721 284 rx-128-255=46 300 276
      rx-256-511=18 225 319 rx-512-1023=7 791 425 rx-1024-1518=350 926 294 rx-too-long=0 rx-broadcast=12 407 rx-pause=0 rx-multicast=2 670 165
      rx-fcs-error=0 rx-align-error=0 rx-fragment=0 rx-jabber=0 rx-drop=1 089 tx-bytes=57 572 061 306 tx-packet=261 519 080 tx-64=24 321 265
      tx-65-127=177 737 420 tx-128-255=22 204 042 tx-256-511=9 857 130 tx-512-1023=5 089 126 tx-1024-1518=22 493 323 tx-broadcast=48 308
      tx-pause=0 tx-multicast=134 918 tx-collision=0 tx-excessive-collision=0 tx-multiple-collision=0 tx-single-collision=0 tx-deferred=0
      tx-late-collision=0 tx-drop=0 tx-fcs-error=0
Other has asked for the same before
viewtopic.php?t=74534
rextended
Re: Last link up time  [SOLVED]
Thu Oct 13, 2022 10:19 am
Really?
:put [/interface get ether1 last-link-up-time]
Jotne
Thu Oct 13, 2022 12:26 pm
My head was not at the right place.
As always short and quick solution by rextended :)
Users browsing this forum: No registered users and 16 guests
