pentorion
Is is possible to bridge two points wirelessly in a 8km distance?
Thu Oct 13, 2022 12:50 am
Is there any combination of mikrotik omni antennas that can create a wireless bridge between two points at a 8km distance (zero obstacles)?
If not, is creating two "pseudo-omni" antennas consisting of 3x120 degrees directional antennas each, a good idea?
The reason I need the "omni" characteristic is that those two points will be slightly rotating and/or moving in a close range (floating in the sea), so directional antennas will lose contact.
What would be the most effective topology?
sirbryan
Re: Is is possible to bridge two points wirelessly in a 8km distance?
Thu Oct 13, 2022 3:23 pm
It depends on how much power you're limited to in the jurisdiction where you're operating those radios.
In the US, a point-to-point link can use as much as 45dB in certain portions of the band. The flip side is point-to-multipoint (which is how you're technically operating if you're using omni's) is limited to as low as 30dB in some portions of the band. And CPE are allowed slightly higher TX power than AP's in some configurations.
Assuming worst-case scenario, the 30dB limit with 20dBi antennas gets you -76dBm and maybe 30Mbps in each direction on 5GHz at 8km on a 20MHz channel. If you have the full 45dB to play with, you could get more bandwidth or use smaller antennas (15dBi) to achieve a similar (or possibly better) result.
With multiple radios at each end, you're also looking at some kind of way to adapt to the changing link. I would go with routers doing OSPF (+BFD if using v6 routers).
For that distance, this gets elaborate pretty quickly.
fragtion
Thu Oct 13, 2022 5:00 pm
Well , you wouldn't want to use omni's for that. I've done 50km+ with 24dbi directional grids and mikrotik radios but that was some years ago, it seems nowadays the integrated kits are more popular
pentorion
Thu Oct 13, 2022 5:07 pm
We're under European regulations.
Can those multiple radios be merged? i.e. can you have 3 directional antennas and a single common output?
sirbryan
Thu Oct 13, 2022 6:04 pm
You could, but you lose 3dB for each split. With the minimum required two splitters, one antenna would be 3dB down and two of the three antennas would be 6dB down. If you used three splitters (to make the third one match), all of them would be 6dB down.
The highest gain dual-polarity 5GHz omni's I've found with just a quick Google search are 13dBi. High-gain 120° sectors run around 16-19dBi. Take 6dB off that, you're down to 10-13dBi anyway. The splitters undo any benefit you'd gain from using sectors with a single radio.
Ultimately, you'd need an array of radios with high-gain, narrow-beam antennas. The highest gain, narrow-beam sectors I've used are Ubiquiti's 22dBi 45° sectors. You'd need eight of those for 360° coverage, and they're not small.
Horns at best will get you 18-20dB over 30°; you'd need 10 of those. For anything over 22dB, you start moving into dish territory, and 23dBi dishes average about 10-13° wide. (20-30 radios doesn't seem very practical.)
Most sectors have an electrical down tilt and a vertical beamwidth of 3°. You'd have to tilt them back to compensate. On rough seas, the antennas would go in and out of vertical alignment constantly. Horns would be a better fit if the water isn't guaranteed to be still the majority of the operating time.
The other factor is budget. Radios will run you anywhere from US$50 to US$250, and antennas from US$250 to $US500. Custom mounting hardware, labor, etc. will bring the price up to thousands of euros/dollars per watercraft.
Don't get me wrong. It would be a fantastic solution to engineer, and actually getting it to work would be exciting. I think understanding the rest of the use case would help to see if alternate solutions would fit the need.
r00t
Long time Member
Long time Member
Thu Oct 13, 2022 6:59 pm
If it's just two points you need to connect (not multiple stations) then use dish antennas and antenna rotators to steer them accordingly. You may only need to do the azimuth if it's a ship on the sea (difference in elevation will be minimal, probably within beamwidth). You would need some another low rate link to exchange positions, but that could be VHF or UHF and very low rate so it works with just omni antennas (could be as slow as 100bps, doesn't really need more than like 1 update per minute).
Some inspiration could be steered antenas used by drone operators for live video or HAM radio community. Also I remembered similar project done by re-purposing Diseqc satellite dish motors. They are "smart" in a way you send them just command "go to +30degress" and it turns. Or CCTV camera mounts.
All this will require some custom arduino programming and HW assembly... but it looks like fun and interesting project.
pentorion
Thu Oct 13, 2022 8:57 pm
Well it seems omnis is the least bad choice. We also thinking about stabilizing the antennas, maybe with gimbals, but that's a very out of the box idea. We'll see. Thanks for the informations.
pentorion
Thu Oct 13, 2022 9:01 pm
I was thinking about an automatic steering system. The only problem is indeed the positioning. We're thinking for a stabilizing algorithm that "seeks for a certain threshold in signal strength and steer acordingly. Could you elaborate on the VHF solution?
sirbryan
Thu Oct 13, 2022 9:08 pm
I just remembered that omnidirectional antennas usually have the same narrow vertical beamwidth (3-5°) and electrical down tilt (usually 2°) that most sectors do. You'll need to factor that in.
sirbryan
Thu Oct 13, 2022 9:16 pm
If the boats have GPS, then you could use some kind of UHF/VHF (or 900MHz) radio to transmit the coordinates. There's amateur radio software (such as APRS) that could be run on a Raspberry Pi and connect to a standard UHF/VHF mobile/marine radio to transmit position data. The receiving computer would calculate the position delta and turn the antenna's motor(s) accordingly.
mkx
Thu Oct 13, 2022 9:56 pm
"omnidirectional" in antenna description most often describes horizontal radiation pattern. As you say it doesn't necessarily describe also vertical radiation pattern, it very much depends on omni antenna construction. However the narrow vertical beam width mentioned is quite unusual and is usually result of using very long antenna (i.e. multiple tens of wavelengths) to achieve higher gain. More oftenly omni antennae feature vertical beamwidths of around 60° - +-30° around horizontal plane . Also keep in mind that realistic omidirectional antenna can never be truly omnidirectional in all 3 dimensions, even simplest dipole has a gap in directions along the dipole. And mind that antenna gain is (generally) inversely proportional to both vertical and horizontal beamwidths, so high gain antennas can never be omnidirectional, they have to be directional (to certain degree) in one or both directions.
sirbryan
Thu Oct 13, 2022 10:27 pm
Understood. Based on the parameters already mentioned in the thread, it is assumed that we want to flatten the pattern from a standard dipole doughnut shape (with a hole the size of the radiating element) to something resembling a pancake so as to get as much gain out along the horizon as possible. And most off-the-shelf 5GHz antennas with the label "omnidirectional" that we would use with MikroTik gear are of that pancake variety, with electrical down tilt creating the effect of the midpoint (doughnut hole) being tweaked upward, like a 5-10mm-tall toothpick in the middle of a stretched out crepe (for a really rough visualization).
mkx
Thu Oct 13, 2022 11:21 pm
... it is assumed that we want to flatten the pattern from a standard dipole doughnut shape (with a hole the size of the radiating element) to something resembling a pancake ...
OP mentioned that installation would be floating on the sea. Which means also swinging due to waves. Depending on floating device (e.g. a buoy) design it might be swinging anything between almost none up to more than 30°. And if expected swinging is anything more than zero, antenna with pancake radiation pattern would definitely not be the right choice. In order to sustain a stable connection (most of time), the antenna radiation pattern choice has to include all of expected floating device movement (OP already mentioned rotation around vertical axis). Only after choice of suitable antenna pattern (on both sides of a PtP link, antennae could be wildly different if physical constraints are different in both locations) it's possible to asses the achievable range of PtP connection.
Don't forget that links over water body (over sea or lake) with Tx/Rx positions low above water experience massive obstruction of Fresnel zone even in line of sight case ... it is half of maximum possible (e.g. if Tx/Rx points are on high masts or on mountain tops) which automatically means considerably reduction of max link distance (or reduction of throughput when link does establish). In reality links over water fare worse than links over flat land (even if geometry of Tx/Rx points is similar) because water usually reflects most energy (and reflected energy is then directed upwards, away from receiver) while land disperses part of energy allowing part of that energy still reach receiver.
timotei
Fri Oct 14, 2022 9:25 am
No experience with situations like this at all, just putting out an idea:
What is needed speed/capacity for this bridge? Would good old 2.4GHz be an option?
Used to have 15dbi omni antennas for 2.4. Mount the antenna 'hanging' (with some extra weight) so gravity (theoretically) evens out the waves.
mkx
Sat Oct 15, 2022 12:05 am
Thus might help in certain conditiins but I guess it wouldn't help at all in other conditions if not making it even worse. For example: floating objects tend to swing so that center of gravity moves the least. If a buoy has most mass in the lower part, then the upper part will be swinging quite a lot. If antenna is hung from upper part (which will swing violently), then in the best case the lower part of antenna (with additional weight attached) will be still, the upper part of antenna will swing and so will horizontal plane of antenna (swinging amplutude will be less than with rigid attachment). In worst case antenna will get into resonance and will swing around like a crazy pendulum with horizontal plane directed in all possible directions... making the situation much worse than with rigid attachment.
Users browsing this forum: Bing [Bot] and 83 guests
