Does anyone know if they can help me.
I have followed the following youtube video for Mikrotik Wireguard setup: https://www.youtube.com/watch?v=CH10spRyGpU
Essentially he gets you to set up a wireguard server, then a peer, then download wireguard on your remote PC, enter in public key, address, DNS, endpoint, allowedIPs and public key of the mikrotik wireguard.
Then he clicks activate and he is able to ping his server remotely.
However I followed this and it won't work. Also when I click activate on my remote PC I lose internet connection which is not good either.
In the video he mentions you MAY have to add a firewall filter rule. He doesn't show this in the video because not all users will need to add this.
Does anyone know if thats why I can't connect?
I have tried to add a filter rule for DST port 13231 in interface: ether1 which is what my WAN cable is connected to.
Thank you.
Code: Select all
# oct/12/2022 23:26:46 by RouterOS 7.4
# software id = JCY8-AFLA
# model = RB2011iL
# serial number = E7DD0F73B4C5
add admin-mac=DC:2C:6E:4C:59:6F auto-mac=no comment=defconf name=bridge
set [ find default-name=ether7 ] name=ether7-access
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
use-peer-dns=yes user=eircom
/interface wireguard
add listen-port=13231 mtu=1420 name=Mikrotik-Wireguard
add comment=defconf name=WAN
add comment=defconf name=LAN
add comment=defconf name=MANAGE
add comment=defconf name=TRUSTED
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=vpn ranges=192.168.89.2-192.168.89.255
add address-pool=dhcp interface=bridge name=defconf
/port
set 0 name=serial0
/ppp profile
set *FFFFFFFE dns-server=192.168.88.1 local-address=192.168.89.1 \
remote-address=vpn
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
/interface l2tp-server server
set enabled=yes use-ipsec=yes
add interface=ether7-access list=MANAGE
/interface pptp-server server
# PPTP connections are considered unsafe, it is suggested to use a more modern VPN protocol instead
set enabled=yes
/interface sstp-server server
set default-profile=default-encryption enabled=yes
/interface wireguard peers
add allowed-address=192.168.34.3/32 interface=Mikrotik-Wireguard public-key=\
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
192.168.88.0
add address=192.168.100.1/24 interface=*D network=192.168.100.0
add address=192.XX.XX.1/24 interface=Mikrotik-Wireguard network=192.XX.XX.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
/ip dhcp-server lease
add address=192.168.88.232 mac-address=00:21:9B:3C:13:ED server=defconf
add address=192.168.88.231 client-id=1:b4:2e:99:16:e1:d0 comment=\
"Lorcan PC C1" mac-address=B4:2E:99:16:E1:D0 server=defconf
add address=192.168.88.218 client-id=1:0:1f:c1:1c:c9:80 mac-address=\
00:1F:C1:1C:C9:80 server=defconf
add address=192.168.88.216 client-id=1:0:1f:c1:1c:c4:20 mac-address=\
00:1F:C1:1C:C4:20 server=defconf
add address=192.168.88.215 client-id=1:0:1f:c1:1c:c4:1b mac-address=\
00:1F:C1:1C:C4:1B server=defconf
add address=192.168.88.214 client-id=1:0:1f:c1:1c:c4:1c mac-address=\
00:1F:C1:1C:C4:1C server=defconf
add address=192.168.88.213 client-id=1:0:1f:c1:1c:c4:8b mac-address=\
00:1F:C1:1C:C4:8B server=defconf
add address=192.168.88.212 client-id=1:0:1f:c1:1c:c4:91 mac-address=\
00:1F:C1:1C:C4:91 server=defconf
add address=192.168.88.211 client-id=1:0:1f:c1:1c:c9:7b mac-address=\
00:1F:C1:1C:C9:7B server=defconf
add address=192.168.88.209 client-id=1:38:22:e2:9f:d:91 mac-address=\
38:22:E2:9F:0D:91 server=defconf
add address=192.168.88.207 client-id=1:0:1f:c1:1c:c4:90 mac-address=\
00:1F:C1:1C:C4:90 server=defconf
add address=192.168.88.206 client-id=1:0:1f:c1:1c:c4:8d mac-address=\
00:1F:C1:1C:C4:8D server=defconf
add address=192.168.88.205 client-id=1:0:1f:c1:1c:c4:8f mac-address=\
00:1F:C1:1C:C4:8F server=defconf
add address=192.168.88.204 client-id=1:0:1f:c1:1c:c4:92 mac-address=\
00:1F:C1:1C:C4:92 server=defconf
add address=192.168.88.203 client-id=1:0:1f:c1:1c:c4:89 mac-address=\
00:1F:C1:1C:C4:89 server=defconf
add address=192.168.88.202 client-id=1:0:1f:c1:1c:c4:1e comment=\
"lorcan phone" mac-address=00:1F:C1:1C:C4:1E server=defconf
add address=192.168.88.201 client-id=1:0:1f:c1:1c:c4:22 mac-address=\
00:1F:C1:1C:C4:22 server=defconf
add address=192.168.88.200 client-id=1:0:1f:c1:1c:c4:8c mac-address=\
00:1F:C1:1C:C4:8C server=defconf
add address=192.168.88.199 client-id=1:0:1f:c1:1c:c4:1f mac-address=\
00:1F:C1:1C:C4:1F server=defconf
add address=192.168.88.198 client-id=1:0:1f:c1:1c:c4:23 mac-address=\
00:1F:C1:1C:C4:23 server=defconf
add address=192.168.88.196 client-id=1:90:9:d0:0:9:11 mac-address=\
90:09:D0:00:09:11 server=defconf
add address=192.168.88.194 client-id=1:0:11:32:ae:a2:7f mac-address=\
00:11:32:AE:A2:7F server=defconf
add address=192.168.88.165 client-id=1:0:1f:c1:1c:c4:8e mac-address=\
00:1F:C1:1C:C4:8E server=defconf
add address=192.168.88.163 client-id=1:34:f6:2d:89:e4:82 mac-address=\
34:F6:2D:89:E4:82 server=defconf
add address=192.168.88.154 client-id=1:0:1f:c1:1c:c4:8a mac-address=\
00:1F:C1:1C:C4:8A server=defconf
add address=192.168.88.92 client-id=1:b8:ec:a3:fd:1d:1f mac-address=\
B8:EC:A3:FD:1D:1F server=defconf
add address=192.168.88.91 client-id=1:b8:ec:a3:fd:1d:1c mac-address=\
B8:EC:A3:FD:1D:1C server=defconf
add address=192.168.88.192 client-id=1:e0:91:f5:c0:c:88 mac-address=\
E0:91:F5:C0:0C:88 server=defconf
add address=192.168.88.217 client-id=1:ec:8e:b5:d9:d7:82 comment="Joyce PC" \
mac-address=EC:8E:B5:D9:D7:82 server=defconf
add address=192.168.88.27 mac-address=6C:2B:59:E6:FB:01 server=defconf
add address=192.168.88.38 client-id=1:0:11:32:b8:2c:31 comment=\
"Backup server" mac-address=00:11:32:B8:2C:31 server=defconf
add address=192.168.88.48 client-id=1:48:2c:a0:79:49:22 comment=\
"lorcan phone" mac-address=48:2C:A0:79:49:22 server=defconf
add address=192.168.88.104 client-id=1:80:5e:c0:a0:3:a3 comment=\
"W60B DECT Base station" mac-address=80:5E:C0:A0:03:A3 server=defconf
192.168.88.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="Wireguard 13231 port allowed" \
dst-port=13231 in-interface=ether1 protocol=udp
established,related,untracked
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add action=accept chain=input comment="allow pptp" dst-port=1723 protocol=tcp
add action=accept chain=input comment="allow sstp" dst-port=443 protocol=tcp
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=accept chain=forward comment="allow internet traffic" \
in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="allow port forwarding" \
connection-nat-state=dstnat
add action=drop chain=forward
add action=masquerade chain=srcnat dst-address=192.168.88.0/24 src-address=\
192.168.88.0/24
add action=src-nat chain=srcnat ipsec-policy=out,none out-interface=ether1 \
to-addresses=XX.XX.XX.XX
add action=dst-nat chain=dstnat comment="FreePBX Media UDP" dst-address=\
XX.XX.XX.XX dst-port=2000-65001 protocol=udp to-addresses=192.168.88.27 \
to-ports=2000-65001
add action=dst-nat chain=dstnat comment="FreePBX WebGUI" dst-address=\
XX.XX.XX.XX dst-port=8080 protocol=tcp to-addresses=192.168.88.27 \
to-ports=8080
add action=dst-nat chain=dstnat comment="FreePBX LetsEncrypt" dst-address=\
XX.XX.XX.XX dst-port=80 protocol=tcp to-addresses=192.168.88.194 \
to-ports=80
add action=dst-nat chain=dstnat comment="FreePBX Tunnel TCP" dst-address=\
XX.XX.XX.XX dst-port=5090 protocol=tcp to-addresses=192.168.88.27 \
to-ports=5090
add action=dst-nat chain=dstnat comment="FreePBX SIP TCP" dst-address=\
XX.XX.XX.XX dst-port=5060 protocol=tcp to-addresses=192.168.88.27 \
to-ports=5060
add action=dst-nat chain=dstnat comment="FreePBX SIP TLS" dst-address=\
XX.XX.XX.XX dst-port=5061 protocol=tcp to-addresses=192.168.88.27 \
to-ports=5061
add action=dst-nat chain=dstnat dst-address=XX.XX.XX.XX dst-port=5500-5501 \
protocol=tcp to-addresses=192.168.88.194 to-ports=5500-5501
add action=dst-nat chain=dstnat dst-address=XX.XX.XX.XX dst-port=443 \
protocol=tcp to-addresses=192.168.88.194 to-ports=443
/ip firewall service-port
set sip disabled=yes sip-timeout=59w3d15h
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/ppp secret
add name=vpn profile=default-encryption
/system clock
set time-zone-name=Europe/Dublin
/tool mac-server
/tool mac-server mac-winbox
