kamyar84
IKEv2 Server [Problem]
Fri Oct 14, 2022 1:20 am
when I try to create identity using auth-method as eap and eap-methods as eap-mschapv2, it return "Couldn't add New IPsec Identity - only eap client supported (6)." What does it means? :-D Does Mikrotik even support this VPN type I want to create? Or I do something wrong?
Users browsing this forum: dioeyandika and 97 guests
