christian178
storm-rate and ingress/egress rate limits Traffic-Storm-Control
Fri Oct 14, 2022 4:13 pm
I have on CRS326-24S+2Q+ on may ports set
set 1 egress-rate=100.0Mbps ingress-rate=20.0Mbps limit-unknown-multicasts=yes limit-unknown-unicasts=yes storm-rate=1
set 2 egress-rate=100.0Mbps ingress-rate=20.0Mbps limit-unknown-multicasts=yes limit-unknown-unicasts=yes storm-rate=1
set 3 egress-rate=100.0Mbps ingress-rate=20.0Mbps limit-unknown-multicasts=yes limit-unknown-unicasts=yes storm-rate=1
set 4 egress-rate=100.0Mbps ingress-rate=20.0Mbps limit-unknown-multicasts=yes limit-unknown-unicasts=yes storm-rate=1
Users on this Port connect via an vlan to PPPoE-Server.
Problem is, that PPPoE Users on this Port not have Download/Upload Speed of 100/20, they have only ~~70/10.
Is there a better way to limit DL UL Speed for Users on Hardware-Level in the Switch?
Christian
netzwerghh
Re: storm-rate and ingress/egress rate limits Traffic-Storm-Control
Thu Feb 16, 2023 12:13 pm
Hallo Christian,
have you found a solution to your problem? We have just realized that we have a similar problem with our CRS317-1G-16S+.
If we just limit egress rate everything works as expected. But if we limit ingress and egress traffic hardly reaches configured limits.
Cheers
Dennis
chechito
Fri Feb 17, 2023 4:59 am
pleaso confirm what version of routeros are you running on your CRS 317
killersoft
Fri Feb 17, 2023 3:14 pm
PPPoE is a CPU based process last I checked.Not sure how the cpu load would look, but isnt a CRS3x a better switch than 'route/network' device.. Would a RB5009 or CCRxxxx series be better to do what you want in PPPoE and QoS..
Anyhow try CPU and use packet/connection marking in mangle and then use Queues to shape traffic...( keep an eye on the CPU load )
netzwerghh
Mon Feb 20, 2023 2:08 pm
It's 7.7.
netzwerghh
Mon Feb 20, 2023 2:11 pm
I think you understand the original poster an me wrong. The switch is just passing the traffic. That's what a switch is for. PPPoE or anything else is made elsewhere in the network. And the CRS3xx is made for SWITCHING so has a horrible CPU for pushing packets. You will NEVER use CPU queues for traffic shaping. But the switch chip should do that. But obviously has problems.
chechito
Mon Feb 20, 2023 3:21 pm
Try ingress ACL to apply the limits, i made some test with 7.6 on CRS 317 and looks like it worked
joshhboss
Wed Feb 14, 2024 4:53 am
Could you please show an example im having the same problem.. and handing off a port tomorrow for a client that is strictly a layer2 hand off.. So no router involved.. and I cant get the Ingress rate limit to work right..
/interface ethernet switch port ingress= does not work properly..
Im trying to accomplish.. 150/150..
Thank you !!
chechito
Wed Feb 14, 2024 5:07 am
Thank you !!
already answered on another topic you created
joshhboss
Wed Feb 14, 2024 5:10 am
Sorry I was kind of look for these specific commands to write the ACLs.. you did mentioned that you got them to work..
I didnt notice that in the post I created..
Sorry maybe im just barking up the wrong tree and I need to find a different switch.
I appreciate your responses.. thank you very much :)
Users browsing this forum: Bing [Bot], CryptoCurrencyDyday, Google [Bot] and 82 guests
