nill
Rest API on PHP with curl
Sun Oct 16, 2022 2:11 pm
Give me please work example how to connet to the rest API
I tried it this way, but it doesn't work
php code
<?php
// options
$EMAIL            = 'admin';
$PASSWORD         = 'pass';
$cookie_file_path = "/tmp/cookies.txt";
$LOGINURL         = "https:/192.168.0.1/rest/system/resource";
$agent            = "Nokia-Communicator-WWW-Browser/2.0 (Geos 3.0 Nokia-9000i)";
// begin script
$ch = curl_init();
// extra headers
$headers[] = "Accept: */*";
$headers[] = "Connection: Keep-Alive";
// basic curl options for all requests
curl_setopt($ch, CURLOPT_HTTPHEADER,  $headers);
curl_setopt($ch, CURLOPT_HEADER,  0);
curl_setopt($ch, CURLOPT_SSL_VERIFYHOST, 0);
curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, true);
curl_setopt($ch, CURLOPT_USERAGENT, $agent);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
curl_setopt($ch, CURLOPT_FOLLOWLOCATION, 1);
curl_setopt($ch, CURLOPT_COOKIEFILE, $cookie_file_path);
curl_setopt($ch, CURLOPT_COOKIEJAR, $cookie_file_path);
// set first URL
curl_setopt($ch, CURLOPT_URL, $LOGINURL);
// execute session to get cookies and required form inputs
$content = curl_exec($ch);
// grab the hidden inputs from the form required to login
$fields = getFormFields($content);
$fields['emailAddress'] = $EMAIL;
$fields['acctPassword'] = $PASSWORD;
// get x value that is used in the login url
$x = '';
if (preg_match('/op\.asp\?x=(\d+)/i', $content, $match)) {
    $x = $match[1];
// set postfields using what we extracted from the form
$POSTFIELDS = http_build_query($fields);
// change URL to login URL
// set post options
curl_setopt($ch, CURLOPT_POST, 1);
curl_setopt($ch, CURLOPT_POSTFIELDS, $POSTFIELDS);
// perform login
$result = curl_exec($ch);
print $result;
function getFormFields($data)
    if (preg_match('/(<form action="op.*?<\/form>)/is', $data, $matches)) {
        $inputs = getInputs($matches[1]);
        return $inputs;
    } else {
        die('didnt find login form');
function getInputs($form)
    $inputs = array();
    $elements = preg_match_all('/(<input[^>]+>)/is', $form, $matches);
    if ($elements > 0) {
        for($i = 0; $i < $elements; $i++) {
            $el = preg_replace('/\s{2,}/', ' ', $matches[1][$i]);
            if (preg_match('/name=(?:["\'])?([^"\'\s]*)/i', $el, $name)) {
                $name  = $name[1];
                $value = '';
                if (preg_match('/value=(?:["\'])?([^"\'\s]*)/i', $el, $value)) {
                    $value = $value[1];
                $inputs[$name] = $value;
    return $inputs;
txfz
Re: Rest API on PHP with curl
Tue Oct 18, 2022 1:47 pm
Examples can be found here:
https://help.mikrotik.com/docs/display/ROS/REST+API
You seem to be attempting to login by scraping some sort of form, which won't work.
Users browsing this forum: InfraErik and 29 guests
