ahmet82
Rb5009 poe in conflict
Sun Oct 16, 2022 5:54 pm
Hello
I have two identical switches. They both provide poe out.
If i connect switch1 to router port 1, and switch2 to router port 2, port1 has uplink but port 2 doesnt have uplink. No led light.
If i connect switch2 to router port 1, and switch1 to router port 2, port1 and port 2 both have uplink
What can be the reason for this?
elbob2002
Re: Rb5009 poe in conflict
Sun Oct 16, 2022 6:00 pm
What are the two identical switches? Make/Model.
Do both have the port you are powering the RB5009 from configured for 802.3af/at ?
ahmet82
Sun Oct 16, 2022 6:35 pm
They are this https://static.tp-link.com/res/down/doc/T1600G-52PS.pdf
Yes they can both power the device from port 1.
It is what happens on port 2 that is weird. One way there is no uplink on port 2. i flip cables and both has uplink
elbob2002
Sun Oct 16, 2022 9:46 pm
Change the cables for new ones?
ahmet82
Sun Oct 16, 2022 10:08 pm
I tried all combination of everything I tried. What's weird is that I used to have a hex s, and it worked without any problems. When I plug the same cables to the same ports on rb5009, it doesn't work. I have to flip them to get them to work
elbob2002
Mon Oct 17, 2022 9:11 am
Last thing I can think of is this thread:
viewtopic.php?t=189042
Supposedly the fix will be in 7.6 - you could test the latest 7.6RC and see if that fixes the issue.
Users browsing this forum: Google [Bot] and 43 guests
