Code: Select all
add check-gateway=ping comment="recursive route for isp1" distance=1 gateway=\
208.67.222.222
add check-gateway=ping comment="recursive route for isp2" distance=1 gateway=\
208.67.220.220
add check-gateway=ping comment="recursive route for isp1" distance=2 gateway=\
208.67.220.220
add check-gateway=ping comment="recursive route for isp2" distance=2 gateway=\
208.67.222.222
add comment=isp2 distance=1 dst-address=208.67.220.220/32 gateway=\
6.7.8.9 scope=10
add comment="black hole for 208.67.220.220" distance=20 dst-address=\
208.67.220.220/32 type=blackhole
add comment=isp1 distance=1 dst-address=208.67.222.222/32 gateway=2.3.4.5 \
scope=10
add comment="black hole for 208.67.222.222" distance=20 dst-address=\
208.67.222.222/32 type=blackhole
