Techsystem
dynamic interface in Bridge
Mon Oct 17, 2022 9:17 am
Hello my friends..!
so in Bridge-Port what it's mean by Dynamic interface as you see in this picture..?
nichky
Re: dynamic interface in Bridge
Mon Oct 17, 2022 10:43 am
everything about that u can manage in interface/list/
Techsystem
Mon Oct 17, 2022 11:43 am
ok.. i agree but if i but an interface as a dynamic what that mean..? also if i put it as a static.
nichky
Mon Oct 17, 2022 12:35 pm
usually i'm creating my own
this is one basic e.g.
add name=exclude
add exclude=exclude include=all name=lan
add interface=ether1 list=exclude
this rule will add all the interfaces into the bridge except ether1
Techsystem
Thu Oct 20, 2022 10:10 pm
Hello Mr @anav ..!
do you have any idea aabout this topic ..? so what is the difference between static and dynamic interface in Mikrotik Router...?
do you have any link or document that explain that..?
Buckeye
Forum Veteran
Forum Veteran
Thu Oct 20, 2022 11:49 pm
Are you not aware of how to use the Google search engine?
How did you create the bridge?
This may offer some insight, if you used /interface bridge port add interface=all
Generally dynamic means something that the system has created when you didn't specify all the parameters.
Techsystem
Fri Oct 21, 2022 6:33 am
Hello Mr Buckeye ..yes i saw this article before, but that didn't give me a full answer..!
Generally dynamic means something that the system has created when you didn't specify all the parameters.. can you go further with this statement ,,?
Buckeye
Forum Veteran
Forum Veteran
Fri Oct 21, 2022 6:36 am
How do I know "you" are not a chat bot?
Techsystem
Sun Oct 23, 2022 9:34 am
1+1=3
Users browsing this forum: AdamT77, HeinoHomm and 106 guests
