Could someone please check my config to see if I'm secure? I forward ports 5800 and 5900 for VNC, and 8123 for Home Assistant.
Thank you!
Code: Select all
# oct/18/2022 05:47:15 by RouterOS 6.49.7
# software id = C3RH-692B
# model = RB750Gr3
# serial number =
add admin-mac=18:FD:00:00:00:00 auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.2.100-192.168.2.200
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address=192.168.2.2/24 comment=defconf interface=bridge network=\
192.168.2.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=192.168.2.0/24 comment=defconf gateway=192.168.2.2 netmask=24
set allow-remote-requests=yes servers=8.8.8.8,1.1.1.1
/ip dns static
add address=192.168.2.2 comment=defconf name=router.lan
add action=accept chain=forward dst-port=5800 in-interface=ether1 log=yes \
protocol=tcp
add action=accept chain=forward dst-port=5900 in-interface=ether1 log=yes \
protocol=tcp
add action=accept chain=forward dst-port=8123 in-interface=ether1 log=yes \
protocol=tcp
established,related,untracked
add action=drop chain=input in-interface=ether1 log=yes
add action=accept chain=forward in-interface=ether1 out-interface=bridge
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
ipsec-policy=out,none out-interface-list=WAN src-address=192.168.0.0/16
add action=src-nat chain=srcnat dst-address=192.168.2.22 dst-port=5800 log=\
yes protocol=tcp to-addresses=192.168.2.22
add action=src-nat chain=srcnat dst-address=192.168.2.22 dst-port=5900 log=\
add action=src-nat chain=srcnat dst-address=192.168.2.176 dst-port=8123 log=\
yes protocol=tcp to-addresses=192.168.2.176
add disabled=yes distance=1 gateway=192.168.2.1
/system clock
set time-zone-name=America/New_York
/system identity
set name=RouterOS
/system ntp client
set enabled=yes primary-ntp=216.239.35.4 secondary-ntp=104.16.132.229
/tool mac-server
/tool mac-server mac-winbox
/tool traffic-monitor
add interface=ether1 name=tmon1
