Artnet44
Automation tool for quick tasks
Tue Oct 18, 2022 1:22 pm
Hello everyone,
Was wondering if anyone might be looking for a little tool to perform some actions on mikrotik units.
The tool is extremely rudimentary at the current point in time, but I am open to suggestions from any of the devs/programmers within the community.
Apologies if this is in the wrong section, not too sure where to share information like this.
Hope this can help somebody out there to save some time or maybe give an idea that can be taken further.
PS: I am only a python hobbyist so apologies for the non-pythonic coding ^^
Link is at: https://github.com/4rt-Net/Mikrotik-Aut ... wissTik.py
Code is as follows:
import argparse
import paramiko
import re
import time
from time import sleep
parser = argparse.ArgumentParser(description='\n~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Created by Art-Net ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~\n\nThe lazy-admin tool to quickly and easily perform functions on RouterOS.\nSpecifically created to save you time and sanity while changing settings remotely.\n\nThis tool uses SSH to open a connection to the target\nDue to SSH being used this tool is sensitive to ssh configuration:\nrequirements: port 22 needs to be open on RouterOS\n\n~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~', formatter_class=argparse.RawTextHelpFormatter)
parser.add_argument(
"--command",
"-c",
default="None",
help=(
"List of commands:\n"
" check-mac\n"
" check-identity\n"
" check-scanlist\n"
" change-radioname\n"
" create-ssl\n"
"--username",
"-u",
default="admin",
help="specify username for login"
"--password",
"-p",
default="None",
help="specify password for login"
"--target",
"-t",
default="0.0.0.0",
help="specify IP address to target"
"--ssl",
"-s",
default="Cert-1",
help="Specify name for ssl certificate"
"--radioname",
"-r",
default="None",
help="specify radio-name for wlan1 interface"
def MacRegex():
	macregex = "([0-9a-fA-F]{2}:){5}[1-9a-fA-F]{2}"
	file = open('temp-maccheck.txt', 'r')
	for lines in file:
   	 matches = re.search(macregex, lines)
   	 if matches != None:
   	   print(matches.group())
def ScanlistRegex():
	scanregex = "scan-list=\d{4}-\d{4}"
	file = open('temp-scanlist.txt', 'r')
	for lines in file:
   	 matches = re.search(scanregex, lines)
   	 if matches != None:
def main(args):
	#Check mac address of wlan1 interface
	if args.command == "check-mac":
		try:
			client = paramiko.SSHClient()
			client.set_missing_host_key_policy(paramiko.AutoAddPolicy)
			client.connect(hostname = args.target , port='22', username= args.username ,password= args.password ,look_for_keys=False)
			print("Connected to: "+(args.target))
			stdin,stdout,stderr = client.exec_command('/interface wireless print')
			output_read = stdout.readlines()
			file=open('temp-maccheck.txt','w')
			file.write(''.join(output_read))
			file.close()
			stdin,stdout,stderr.flush()
		except:
			print("# Connection failed to: ", args.target)
			print("check that the port 22 is open on the target")
		finally:
			client.close()
			MacRegex()
	#Check scanlist of unit
	elif args.command == "check-scanlist":
		try:
			file=open('temp-scanlist.txt', 'w')
			file.close()
		except:
		finally:
			client.close()
			ScanlistRegex()
	#Check system identity of unit
	elif args.command == "check-identity":
		try:
			stdin,stdout,stderr = client.exec_command('/system identity print')
			print(output_read)
		except:
		finally:
			client.close()
	elif args.command == "change-radioname":
		try:
			stdin,stdout,stderr = client.exec_command('/interface wireless set wlan1 radio-name='+str(args.radioname))
			print("Unit is reconnecting, radio-name changed to:"+str(args.radioname))
			print("closing ssh connection...")
			client.close()
		except:
	elif args.command == "create-ssl":
		try:
			print("Creating SSL Certificate...")
			stdin,stdout,stderr = client.exec_command('/certificate add name='+(args.ssl)+' common-name='+(args.ssl)+' key-usage=key-cert-sign,crl-sign key-size=2048 trusted=yes days-valid=1175')
			print("Done")
			stdin,stdout,stderr = client.exec_command(('/certificate sign '+(args.ssl)+' name='+(args.ssl)+' ca-crl-host='+(args.target)))
			print("Signing certificate, please wait...")
			time.sleep(20)
			print("Done")
			print("Assigning certificate to API-SSL service...")
			stdin,stdout,stderr = client.exec_command('/ip service set api-ssl certificate='+(args.ssl))
			print("SSL Certificate completed!")
			client.close()
		except:
if __name__ == "__main__":
	main(parser.parse_args())
rextended
Re: Automation tool for quick tasks
Tue Oct 18, 2022 1:59 pm
If radio name contain space do not work, must be radio-name="<NAME>"
SONAR? "/certificate sign sonar name="
and everywere are missing the " on winbox commands (when involved text).
Artnet44
Tue Oct 18, 2022 2:08 pm
Hi Rextended, thanks for pointing out.
Will see if I can rework the ssl portion and edit as needed
For now I removed the parts giving issues until I can find a working solution
rextended
Tue Oct 18, 2022 2:09 pm
A valid RegEx for MAC is ([0-9a-fA-F]{2}:){5}[1-9a-fA-F]{2}
(?:[0-9a-fA-F]: ?){12} match also aaaaaaaaaaaa or 2003:beef:0430:
Artnet44
Tue Oct 18, 2022 2:35 pm
I see what you mean with the mac regex, tested it on a unit.
Thanks a mil!
I've updated the regex & changed code slightly for ease of reference. :)
The SSL problem has been resolved, will tackle radio-name with spaces issue next.
Here is the revised code:
import argparse
import paramiko
import re
import time
"--command",
"-c",
default="None",
help=(
" check-mac\n"
" check-identity\n"
" check-scanlist\n"
" create-ssl\n"
"--username",
"-u",
default="admin",
"--password",
"-p",
default="None",
"--target",
"-t",
default="0.0.0.0",
"--ssl",
"-s",
default="Cert-1",
"--radioname",
"-r",
default="None",
def MacRegex():
	for lines in file:
   	 if matches != None:
	for lines in file:
   	 if matches != None:
def main(args):
		try:
			file.close()
		except:
		finally:
			client.close()
			MacRegex()
		try:
			file.close()
		except:
		finally:
			client.close()
			ScanlistRegex()
		try:
			print(output_read)
		except:
		finally:
			client.close()
		try:
			client.close()
		except:
		try:
			print("Done")
			time.sleep(20)
			print("Done")
			client.close()
		except:
Users browsing this forum: No registered users and 14 guests
